Table model colors
- persei8
- Thank you received: 133
13 Jul 2021 20:23 #214663
by persei8
Table model colors was created by persei8
The current tool and offset tables have highlight and selected colors that do not play nice with my current stylesheet. I modified the code so I could set the highlight and selected colors from the handler.It could also be a designer parameter (thus no handler code mods), if you decide to incorporate this change,
Thank you.
def highlight(self, color):
self.tablemodel._highlightcolor = QColor(color)
def selected(self, color):
self.tablemodel._selectedcolor = QColor(color)Thank you.
- Thank you received: 2181
13 Jul 2021 22:13 #214670
Replied by cmorley on topic Table model colors
Thanks Jim.
I added your functions and added the properties too.
I also did the same for originoffsetview.
so you can call the functions with a color string:or
set the property with a QColor object :or
set in designer or
set with stylesheet.
Chris
self.w.tooloffsetview.highlight('red')set the property with a QColor object :
self.w.tooloffsetview.setProperty('styleColorHighlight',QColor('red'))set in designer or
#tooloffsetview{
qproperty-styleColorSelection: orange;
qproperty-styleColorHighlight: pink;
#offset_table{
}Chris
The following user(s) said Thank You: persei8
Time to create page: 1.036 seconds
