QTDragon run from line dialog when not enabled
- coredump
22 Aug 2021 23:04 #218448
by coredump
Replied by coredump on topic QTDragon run from line dialog when not enabled
Also as far as I know, the widget_dialog.py that I got is the one on master github.com/LinuxCNC/linuxcnc/blob/master...ets/dialog_widget.py
- Thank you received: 2181
23 Aug 2021 01:56 #218453
Replied by cmorley on topic QTDragon run from line dialog when not enabled
Ok I got a guess.
I use a hack to open the details display, which is essentially a forced button press.
I bet different versions of qt press a different button.
Could you try editing a file? (not sure where you are in experience.)
The dialog_widget.py needs to be edited.
need to remove this code:
Chris
# force the details box open on first time display
if self._flag and details != ' Tool Info: ':
for i in self.buttons():
if self.buttonRole(i) == 3:
i.click()
self._flag = False
Chris
23 Aug 2021 02:44 #218455
I'm pretty sure this is the problem so I changed the code in master to this:
Which checks a little harder to make sure it internally presses the right button.
if self.buttonRole(i) == QMessageBox.ActionRole:
if i is self._actionbutton: continue
i.click()
self._flag = False
The following user(s) said Thank You: coredump
23 Aug 2021 02:46 #218456
Oh and jumplist info is held in the preference file.
you can edit it when qtdragon is not running and the next time it is started it will use the new preferences.
23 Aug 2021 02:47 #218457
And is there was an error message that crashes the screen I would like to know the details please.
- coredump
23 Aug 2021 21:37 #218553
by coredump
Thanks @cmorley. That did it. Ran two different programs today and while my PCBs continue to suck, the interface behaved perfectly!
About the jump list: I don't even have anything on the prefs file, and it still complaining that it can't find '/media/coredump' that has been deleted a while ago but still on the jump list.
I haven't find any interface breaking error yet, but I am sure some will appear since the python changes are still ongoing.
Thanks for looking into this!
24 Aug 2021 00:49 #218567
Thanks for the feedback! that was a tough one
Jump list is recorded only in the pref file..maybe a different one then you are checking?
- coredump
24 Aug 2021 02:49 #218574
by coredump
Yeah that was a weird bug. Thanks again.
And I don't see how it could be a different preference file:
coredump@cnc:~/6040
$ grep pref * -R
6040.ini:PREFERENCE_FILE_PATH = WORKINGFOLDER/qtdragon.pref
hallib/6040.hal:# qtdragon prefers their own
qtdragon_ini.log:2021-08-23 18:11:23,256 - QTvcp - INFO - Preference path: /home/coredump/linuxcnc/configs/6040/qtdragon.pref
qtdragon.pref:notify_start_detail = This option can be changed in the preference file
coredump@cnc:~/6040
$ grep -iA4 -B3 jump /home/coredump/linuxcnc/configs/6040/qtdragon.pref
notify_start_timeout = 5
[FILEMANAGER_JUMPLIST]
[CUSTOM_FORM_ENTRIES]
Tool to load = 5
Laser X = 100.0Please Log in or Create an account to join the conversation.
24 Aug 2021 02:55 #218576
Well user and media are always added by default.
Are those the ones you mean?
- coredump
24 Aug 2021 03:01 #218577
by coredump
Oh, well, that explains then
Sorry about that. I guess I will just creat the damned directory
Time to create page: 0.745 seconds
