Using a USB joystick to jog in QtDragon
- frayja2002
- Thank you received: 13
21 Aug 2021 03:40 #218298
by frayja2002
Replied by frayja2002 on topic Using a USB joystick to jog in QtDragon
That is where they are saved with the original names.
I have set the permissions to wr user & group.
I have also tried changing the names to Router_01.py etc
Always the same.
I have reposted the latest & my ini file just incase.
Always the same.
- frayja2002
21 Aug 2021 03:47 #218299
by frayja2002
I don't know if its relevant but I just noticed that these log files are being created in my home dir.
- Thank you received: 2181
21 Aug 2021 03:53 #218300
Replied by cmorley on topic Using a USB joystick to jog in QtDragon
When you say original name, do you mean
qtdragon_handler.py
qtdragon.ui
I see the files I posted got their names changed by the forum.
qtdragon_handler.py
qtdragon.ui
- frayja2002
21 Aug 2021 04:06 #218301
by frayja2002
Yes that is working now.
I can see the new halpin.
Thanks for all you help & your persistance.
Its much appreciated.
21 Aug 2021 04:10 #218302
Excellent!
if there is a 2.8.3 release you will need to remove those files to see the qtdragon update.
The pin name will change slightly.
Chris
Chris
- frayja2002
21 Aug 2021 04:12 #218303
by frayja2002
Just one other quick thing.
Withe the new files loaded up the graphics are missing from the jog buttons.
Having made the hal connections it seems to be working as expected otherwise.
- frayja2002
21 Aug 2021 04:16 #218304
by frayja2002
I don't know if it heaps but here are those files again (just incase they actually mean anything).
21 Aug 2021 04:27 - 21 Aug 2021 04:28 #218305
try copying the folder:
/usr/share/qtvcp/images
into:
/home/alex/linuxcnc
Chris
into:
/home/alex/linuxcnc
Chris
Last edit: 21 Aug 2021 04:28 by cmorley.
- frayja2002
21 Aug 2021 04:35 #218306
by frayja2002
Yep. That fixes it.
Time to create page: 0.105 seconds
