QtDragon feature request go_to_zero
4 years 10 months ago #230112 by cmorley
I only added it to qtdragon.
I don't see an available and appropriate place to put them - do you?
4 years 10 months ago #230113 by ucancallmebob89
Oh from context I thought they were present but hidden. Idk, assuming the jogging buttons are a 3x6 grid (including when the A axis is present), maybe put them right next to the Z+ and Z- buttons?
I agree that's not necessarily the best place. It would be nice to have a dedicated area where we could have a handful of MDI shortcut buttons.
Maybe instead on the main view tab we could have a right-justified column with several MDI command buttons? What do you think?
4 years 10 months ago #230115 by cmorley
If you like uncompess this folder in your config folder and try it out.
you'll need to add this to INI:
[MDI_COMMAND_LIST]
MDI_COMMAND = G0 Z0;X0 Y0
MDI_COMMAND = G53 G0 Z0;G53 G0 X0 Y0
you can add a third MDI command for the user button.
If it doesn't create usability problems we can talk about adding it to linuxcnc.
Chris
4 years 10 months ago #230116 by cmorley
Removing or Renaming the folder will return the original qtdragon_hd
4 years 10 months ago #230117 by cmorley
Maybe the position in qtdragon is better - it just seemed to close in qtdragon_hd.
But I don't use it everyday so I'll take advisement.
4 years 10 months ago - 4 years 10 months ago #230147 by hottabich
For the safety of the machine, there should be no buttons (go_to) in the foreground, I think so. I suggest the following as in the screenshots.
Last edit: 4 years 10 months ago by hottabich.
Time to create page: 0.197 seconds
