QtDragon feature request go_to_zero
5 years 2 months ago #218449 by frayja2002
Hi there
Just a not to confirm that that all works.
I have uploaded a default ini file (for qtdragon) with some comments added which I thought it might be a good thing so that people will know what is these are for.
I have run this and tested it on a real machine to confirm that everything works as expected & just to confirm you can substitute you own gcode file in the form of...
MDI_COMMAND = O<go_to_zero> call
for those that want to do so (which makes this a really flexable tool)
On a side note I noticed that when I went through the pconf wizard to setup a new machine that the probe screen button was missing, however when I created a sim machine the probe button was there.
Am I missing something that I have to setup?
5 years 2 months ago #218452 by cmorley
I don't see the uploaded file.
Thanks for the feedback.
I should add something to the docs.
for probing add this to INI
[PROBE]
#USE_PROBE = versaprobe
USE_PROBE = basicprobe
5 years 2 months ago #218464 by frayja2002
Sorry, rushing around a bit.
5 years 2 months ago #218465 by cmorley
the [MDI_COMAND_LIST] is in there twice
I updated the docs a bit for qtdragon in master.
4 years 10 months ago #230110 by ucancallmebob89
Sorry for reviving an old thread but I don't see either of the "go to zero" buttons in qtdragon_hd. Is that an option I need to enable?
4 years 10 months ago #230111 by ucancallmebob89
I'd be fine writing my own OWord routine but I'm not sure how to make the buttons visible, if they exist.
From the qtdragon docs:  linuxcnc.org/docs/devel/html/gui/qtdragon.html
Time to create page: 0.058 seconds
