Machine Log
01 Sep 2021 22:05 - 01 Sep 2021 22:06 #219390 by phillc54
Replied by phillc54 on topic Machine Log
Yeah, I just tried it and you can have a tool numbered -1 in the tool table, I wonder why?
I had always assumed tool #0 was the default tool but I see now that is not the case.
Some confusing stuff here, what I don't understand is is I run this code at the end of initialized in the handler
        self.stat = linuxcnc.stat()
        self.stat.poll()
        print("\n######\n", self.stat.tool_in_spindle)
        print(self.stat.tool_table[0][0], "\n######\n")
The result is:
 0
-1
Last edit: 01 Sep 2021 22:06 by phillc54.
01 Sep 2021 22:43 #219391 by cmorley
Replied by cmorley on topic Machine Log
I would bet one is just initialized wrong in the c/c++ code - cause - which number is right?
01 Sep 2021 22:45 #219392 by phillc54
I would like the zero to be correct but I am guessing it is not.
01 Sep 2021 22:47 #219393 by cmorley
Might be worth putting in a bug report to get a discussion going.
01 Sep 2021 22:52 #219394 by phillc54
a quick look at emcmodule.cc shows:
    {(char*)"tool_in_spindle", T_INT, O(io.tool.toolInSpindle), READONLY,
        (char*)"The tool number of the currently loaded tool, or 0 if no tool is loaded."
considering that tool #0 is a valid tool then my guess is that should be -1 if no tool is loaded so it is the same as tool_table[0][0]
02 Sep 2021 01:26 - 02 Sep 2021 01:28 #219405 by phillc54
More confusion, I think it may be best to just hide the first write to the machine log:
This code:
print("\n######")
print(" self.stat.tool_in_spindle: {:2} self.stat.tool_table[0][0]: {:2}".format(self.stat.tool_in_spindle, self.stat.tool_table[0][0]))
print("STATUS.stat.tool_in_spindle: {:2} STATUS.stat.tool_table[0][0]: {:2}".format(STATUS.stat.tool_in_spindle, STATUS.stat.tool_table[0][0]))
print("######\n")
produces this result:
self.stat.tool_in_spindle: -1 self.stat.tool_table[0][0]: -1
STATUS.stat.tool_in_spindle: 0 STATUS.stat.tool_table[0][0]: -1
Maybe it is just a timing issue during startup.
Last edit: 02 Sep 2021 01:28 by phillc54.
  • snowgoer540
  • snowgoer540's Avatar Topic Author
  • Moderator
  • Moderator
02 Sep 2021 05:02 - 02 Sep 2021 05:04 #219424 by snowgoer540
Replied by snowgoer540 on topic Machine Log
It's strange that no one has officially made linuxcnc remember the last tool it used before shutdown.
I would have thought it reasonably simple for a dev who knows the code.
The only LCNC gui that I have significant experience with, regarding tool changes (with no Automatic Tool Changer), is PathPilot and PathPilot remembers the last tool used every time you start it. Which means that they either "fixed" it, or it broke on our end at some point since they forked off.
I think that's what lead me down the path of thinking that the GUI sets the last tool used on startup, but it seem now this is not the case.
From a QtPlasmaC standpoint, I suppose it's not the end of the world.
For everyone else using tool changes, it seems like LCNC forgetting the last tool used would be inconvenient.
I also find it a bit interesting that LCNC does remember the last tool if you have "RANDOM_TOOLCHANGER" set to 1, but I've also not looked into why/the code at all.
Last edit: 02 Sep 2021 05:04 by snowgoer540.
Time to create page: 0.982 seconds
