??? how to load a custom gui file ???
  • Roguish
  • Roguish's Avatar Topic Author
  • Elite Member
  • Elite Member
07 Nov 2021 16:53 #225597 by Roguish
Replied by Roguish on topic ??? how to load a custom gui file ???
Holy guacamole. that did it.....
thanks.
Cmorley. thanks. could you add the joint velocities to hal_glib as you did the following errors? they are in the joint dictionary.
thanks.
07 Nov 2021 23:16 #225625 by cmorley
Replied by cmorley on topic ??? how to load a custom gui file ???
Glad you got it working.
I'm curious why joint velocities is something you would track continuously.
I'm assuming you wish to use LCD rather then statusLabel to display joint velocities?
To answer a previous question:
STATUS is hal_glib with a qt Jacket on it (technically it subclasses it).
The following user(s) said Thank You: Roguish
  • Roguish
  • Elite Member
  • Elite Member
08 Nov 2021 08:53 #225696 by Roguish
My mill has tuning and performance issues.  Watching the following error vs. velocity and time (as distance travelled) helps me work on the tuning.
Yes, I like the LCD display.  Of course I'll have to figure out how to set the format.  Velocity being something like:  123.4   Ferror being like:  0.12345
Again.   I do appreciate your assistance.
  • Roguish
  • Elite Member
  • Elite Member
08 Nov 2021 18:16 #225740 by Roguish
cmorley.
I added the joint velocity to hal_glib.py..................and it works.  Using the LCDNumber.    Just followed your lead on the ferror.
It's probably not pretty.  Please clean it up if you wish.  Just let me know, if and when you push it.  I do like to stay current with the real source.
  • Roguish
  • Elite Member
  • Elite Member
09 Nov 2021 15:45 #225881 by Roguish
Cmorley,
well, i've worked out my formatting for both the following error and the velocity.
BUT encountered a small problem.
The velocity is shown in units/sec, rather than units/min.
I see in hal_glib.py there is some simple conversion math done on some other data, but none that are really like the velocity
attached is the modified hal_glib.py.       see lines  211, 322, 330, 554, 871
check the math in the max-velocity-override-changed    in line 596
would you give a little guidance, please?  which line and what?
or should this be done in the handler file?  and how?
thanks.
09 Nov 2021 22:17 #225918 by cmorley
Sorry I've been busy with work lately. try:
veloc.append(self.stat.joint[j]*60)
  • Roguish
  • Elite Member
  • Elite Member
10 Nov 2021 10:13 #226000 by Roguish
THANKS. WORKS.
I added a *60
ferror.append(self.stat.joint[j])
Time to create page: 0.138 seconds
