QtDragon user view persistance
16 Sep 2021 19:04 #220834 by frayja2002
QtDragon user view persistance was created by frayja2002
Hi there
I am using the latest development version of QtDragon (not HD) & notice that we now have near the preview window a user view button which is a great thing.
I was wondering if it would be possible to have the record view to be persistent across sessions, so that when you restart linuxcnc you can just press the button & go straight to you favorite position?
16 Sep 2021 20:25 #220845 by cmorley
Replied by cmorley on topic QtDragon user view persistance
yes I think we could do this.
The user view is an experiment - in my testing it wasn't always perfect but It was really useful.
What did you find?
17 Sep 2021 18:55 #220963 by cmorley
I pushed work to have user view saved in the preference file.
Chris
18 Sep 2021 01:55 #220976 by frayja2002
Replied by frayja2002 on topic QtDragon user view persistance
I have tried it and it seems to be working.
Slightly off topic but I have a couple of other questions...
With the "goto" buttons in the XYZ jog area would it be possible to have the one labeled "Goto Origin" changed to something like "Goto WCO"
Just so that I don't heep getting it confused with a "Goto machine origin"
Also I notice that to start the g-code the button says START LINE as opposed to QtDragon_HD which has the more traditional CYCLE START.
Does that mean I could accidentally start my g-code half way through if I'm not careful or is it just a differnt name for the same thing?
As always thanks for your immediate response & continuing improvements.
18 Sep 2021 01:57 #220977 by frayja2002
PS I don't know if you intend to, but I didn't see the save view button in QtDragon_HD yet.
18 Sep 2021 02:57 #220978 by cmorley
run-from-line option must be selected in the settings tab.
Then you select the line you want to start at. the line number is reflected in the button label.
As well as that, a dialog will pop up to give you start options.
So it would be hard to do this accidentally.
But i changed the label to cycle start when the run-from-line option is off.
I added user view to dragon_hd
18 Sep 2021 07:58 #220998 by frayja2002
Hi there.
I have just had a look at all of the changes & everything looks good except that the goto mchn zero button is appears to be going to the work zero.
Could you possibly double check this.
18 Sep 2021 11:31 #221022 by cmorley
Sorry - fixed
The following user(s) said Thank You: ikkuh
Time to create page: 1.140 seconds
