Gcode editor saving/loading problems
25 Sep 2021 17:47 - 25 Sep 2021 17:50 #221566 by bednarzmac
Gcode editor saving/loading problems was created by bednarzmac
Hi, I have a problem with gcode editor widget. When i'm getting it in edit mode:
def EditButton(self): self.w.gcode_editor.editMode()
I can edit the code, make blank file, find phrases, undo and redo but I can't Save and open file via icons from Gcode editor.
Might be i need another library to get it work? Any suggestions?
Loading libraries:
import sys
import os
import linuxcnc
import hal from PyQt5
import QtCore, QtWidgets, QtGui from qtvcp.widgets.mdi_line
import MDILine as MDI_WIDGET from qtvcp.widgets.gcode_editor
import GcodeEditor as GCODE from qtvcp.widgets.stylesheeteditor
import StyleSheetEditor as SSE from qtvcp.lib.keybindings
import Keylookup from qtvcp.core
import Status, Action, Info
# Set up logging from qtvcp import logger LOG = logger.getLogger(__name__)
Last edit: 25 Sep 2021 17:50 by bednarzmac.
25 Sep 2021 18:47 #221569 by cmorley
Replied by cmorley on topic Gcode editor saving/loading problems
Are you building a custom screen or using an existing screen?
By default it calls a file_dialog for loading and saving using special STATUS messages
This means you must have a filedialog that responds to the call.
The normal way to do this is to use the screen_options widget to set one up.
You can also 'class patch' the load and save function calls to do something else.
QtDragon for instance does this to trap those buttons.
The following user(s) said Thank You: bednarzmac
26 Sep 2021 09:21 #221621 by bednarzmac
Replied by bednarzmac on topic Gcode editor saving/loading problems
Hi, i'm using highly modificated qttouchy (still working on it). Screen_options solution works like a charm!:) Thank You!
26 Sep 2021 18:01 #221655 by cmorley
Cool - I would love to see your work when finished - Touchy as is, is pretty ugly :)
Time to create page: 0.079 seconds
