QtDragon homing routines.........
  • Roguish
  • Roguish's Avatar Topic Author
  • Elite Member
  • Elite Member
04 Oct 2021 20:59 #222218 by Roguish
QtDragon homing routines......... was created by Roguish
Does Qtdragon follow the standard homing routines as defined in the Linuxcnc docs?
I copied my .ini file (from axis) to a dragon setup.
The Y homing in axis worked fine.   Drove to the switch, tripped the switch, reversed to search for the index, found the index, and moved to the final home.
I Qtdragon, it drove to the switch, tripped the switch, DID NOT reverse, instead continued in the same direction to fine the index, and instead it destroyed the switch...............
Not good.
Waz Up?.
  • Moderator
  • Moderator
04 Oct 2021 21:54 #222224 by tommylight
Replied by tommylight on topic QtDragon homing routines.........
Switch in the wrong place.
Switches should be mounted always such that nothing can break them, machine must have hard stops, not use switches as hard stops.
Not using QtDragon so not sure, although it should be same as in Axis.
Putting a - in front of the home_latch_velocity value should fix that, but again not sure about QtDragon.
Sorry, not helping, but i really like QtDragon but i do not have time to finish my mill so i can use it, but if it does not use the default homing stuff from LinuxCNC i am sure i will not use it, i just do not like messing with the bullet proof reliability of LinuxCNC and homing is a major part of that.
The following user(s) said Thank You: Roguish
  • Roguish
  • Elite Member
  • Elite Member
04 Oct 2021 22:34 #222234 by Roguish
Replied by Roguish on topic QtDragon homing routines.........
figured it out.
my stupid.
switching directions of homing, i also have to change the home input in the io.hal file.....
doh.
05 Oct 2021 01:07 #222235 by cmorley
Replied by cmorley on topic QtDragon homing routines.........
I'm sorry to hear of your problem.
QtDragon uses default jogging process.
Chris
  • Moderator
  • Moderator
05 Oct 2021 10:00 #222264 by tommylight
Thank you Chris for confirming that.
Time to create page: 0.278 seconds
