Is there a "step back" function
03 Nov 2021 01:23 #225062 by yi2580
Is there a "step back" function was created by yi2580
Hello, I'm customizing an interface, but I need a function now. I can't find it there, or whether linuxcnc has this function. Whether there is a "step back" function when executing G code. I found that it has the function of "step".
03 Nov 2021 01:39 #225064 by tommylight
Replied by tommylight on topic Is there a "step back" function
The included sims of PlasmaC and QtPlasmaC have that feature, pretty sure there are other sims that use it, search for "jog while paused", not sure if it fits exactly what you need.
03 Nov 2021 02:51 #225066 by yi2580
Replied by yi2580 on topic Is there a "step back" function
Hello! Thank you very much for your answer. I may not have expressed my question clearly. The fallback function I want is to return to the G code executed on the previous line. Can this be achieved?
Thank you again for your reply
03 Nov 2021 08:17 #225076 by cmorley
Replied by cmorley on topic Is there a "step back" function
linuxcnc does not have a step back function.
It has a reverse run function or run-from-line function.
04 Nov 2021 01:10 #225181 by yi2580
Hello, thank you for your answer. What is the reverse run function or run from line function you said, and how should I use it
