Change the "Mouse Button Mode" of QTdragon
  • tuzki
  • tuzki's Avatar Topic Author
  • Senior Member
  • Senior Member
20 Nov 2021 05:33 #227052 by tuzki
Hello everyone。
I want to change the "mouse button mode" of QTdragon. I want to use the middle button of the mouse to rotate and the left button to move.
I don't know how to make changes in QTdragon, can you help me. thanks.
21 Nov 2021 06:00 #227166 by cmorley
Replied by cmorley on topic Change the "Mouse Button Mode" of QTdragon
Currently this is not easy for a user to change.
Is it a preference or a usability issue?
  • tuzki
  • Senior Member
  • Senior Member
23 Nov 2021 03:14 #227363 by tuzki
Replied by tuzki on topic Change the "Mouse Button Mode" of QTdragon
this a preference.I am used to that way of operation.
26 Nov 2021 23:35 #227711 by cmorley
Are you using master version of linuxcnc? I added a way to change the button controls with styesheets.
#gcodegraphics{
qproperty-MouseButtonMode:3;
  • tuzki
  • Senior Member
  • Senior Member
28 Nov 2021 08:46 #227802 by tuzki
Thank you for your answer. Do I need to add this code to a file? Or I just need to execute the update command
29 Nov 2021 08:01 #227875 by cmorley
You must use master branch (2.9).
You must have the latest changes.
Then start qtdragon a press f12
Then use the editor to add the code I posted.
  • tuzki
  • Senior Member
  • Senior Member
29 Nov 2021 16:11 #227918 by tuzki
OK, thank you for your answer
Time to create page: 1.445 seconds
