How to set up M1?
  • chen1234
  • chen1234's Avatar Topic Author
  • Senior Member
  • Senior Member
17 Dec 2021 08:20 #229275 by chen1234
How to set up M1? was created by chen1234
I used qtvcp to make an interface, and when I tested the G code pause function, I saw M1 (execution pause), and I need to turn on the optional switch (linuxcnc.org/docs/2.8/html/gcode/m-code. html#mcode:m0-m1), then how should I use the M1 pause switch? Where can I see this settings section?
18 Dec 2021 00:44 #229355 by cmorley
Replied by cmorley on topic How to set up M1?
I'm not sure I completely understand...
In qtvcp, the action button's action: 'Optional_stop' controls the response to M1
The following user(s) said Thank You: chen1234
  • Todd Zuercher
  • Todd Zuercher's Avatar
  • Platinum Member
  • Platinum Member
20 Dec 2021 17:31 #229563 by Todd Zuercher
Replied by Todd Zuercher on topic How to set up M1?
Alternately you can use a halui hal pin to toggle the optional stop state, there are these three Halui pins related to it.
halui.program.optional-stop.is-on
halui.program.optional-stop.off
halui.program.optional-stop.on
The first is an output that shows the optional stop state, the other two are inputs for changing the state.
Time to create page: 0.075 seconds
