[QtDragon] Connecting output pin to I/O message pin.
21 Jan 2022 21:22 - 21 Jan 2022 21:36 #232684 by RomeReactor
Hi all. According to the documentation on user messages for qtvcp and  qtdragon , it's possible to add user created messages in qtdragon's ini file, just like on gmoccapy. However, the resulting pin for okdialog messages is an I/O pin, which can't be connected to output bit pins. I need to be able to connect classicladder out pins to the message trigger. Is there a way to do so? Using linuxcnc 2.8.2 on Debian Buster.
Thanks in advance.
Last edit: 21 Jan 2022 21:36 by RomeReactor. Reason: Added more details
21 Jan 2022 21:57 #232689 by RomeReactor
Found this component , just changed float to bit, and now the messages work.
Time to create page: 0.157 seconds
