How to refresh the DRO
- yi2580
- Thank you received: 3
11 Feb 2022 07:41 #234555
by yi2580
How to refresh the DRO was created by yi2580
I'm using pyqt5 to write interface code, but I don't think his dro refresh is very timely, so I want to ask you whether there is a function to refresh the dro data of linuxcnc, so that I can get his data more quickly
- Grotius
- Thank you received: 2349
20 Feb 2022 19:33 #235416
by Grotius
Replied by Grotius on topic How to refresh the DRO
I think in the python-gui thread wich is around 100-200ms i remember.
The refresh time can be set.
I suggest the easyest way is to edit the gui-update time. ~100ms is quite fast. ~50ms is ultra fast but can cause other problems.
- robertspark
- Thank you received: 216
20 Feb 2022 19:40 - 20 Feb 2022 19:40 #235417
by robertspark
Replied by robertspark on topic How to refresh the DRO
Is CYCLE_TIME the setting you are looking for? (bottom of the list)
linuxcnc.org/docs/devel/html/config/ini-...tml#_display_section
Last edit: 20 Feb 2022 19:40 by robertspark.
- yi2580
07 Mar 2022 04:55 #236559
by yi2580
Replied by yi2580 on topic How to refresh the DRO
OK, thank you very much for your reply and found a solution
Time to create page: 0.155 seconds
