Touch_plate in QrDragon doesn't function as described
29 Apr 2022 02:30 #241599 by ggsxx
Hi i have for a while been trying to find the routine that the Touch_plate buton in QtDragon uses to no avail.I have found one in macros of probe and an other in basic probe.Both of them are described has moving towear surface then backing up 1mm and touching the srface slower. When i use it the surface is only touched once and the Zero is set in aboslute.Also the zero is highre then the touch plate dimension.
Any one knows where is the correct path for the routine?
29 Apr 2022 06:34 #241609 by cmorley
Are you talking about QtDragon which is included with linuxcnc?
If so that uses qtvcp not QtPyVCP - so wrong category.
What version of linuxcnc are you using?
The following user(s) said Thank You: ggsxx
29 Apr 2022 10:09 #241624 by ggsxx
Yes i am. Thank you.
29 Apr 2022 10:53 #241627 by phillc54
Moved to QtVCP
29 Apr 2022 12:36 #241634 by cmorley
in 2.8 the touchoff code is in the handler file:
github.com/LinuxCNC/linuxcnc/blob/2.8/sh...agon_handler.py#L723
14 May 2022 14:27 #242954 by ggsxx
I am trying to locate thr handler.py file but can't find it.
14 May 2022 16:11 #242958 by cmorley
run linuxcnc in a terminal, you'll see a line like:
..... 'Using DEFAULT handler file path:SOMEPLACE'
Copy that file to your config folder and qtvcp will use the config folder version.
In this way updates won't overwrite your modified file.
The following user(s) said Thank You: ikkuh
