Touch_plate in QrDragon doesn't function as described
4 years 6 months ago #241599 by ggsxx
Hi i have for a while been trying to find the routine that the Touch_plate buton in QtDragon uses to no avail.I have found one in macros of probe and an other in basic probe.Both of them are described has moving towear surface then backing up 1mm and touching the srface slower. When i use it the surface is only touched once and the Zero is set in aboslute.Also the zero is highre then the touch plate dimension.
Any one knows where is the correct path for the routine?
4 years 6 months ago #241609 by cmorley
Are you talking about QtDragon which is included with linuxcnc?
If so that uses qtvcp not QtPyVCP - so wrong category.
What version of linuxcnc are you using?
The following user(s) said Thank You: ggsxx
4 years 6 months ago #241624 by ggsxx
Yes i am. Thank you.
4 years 6 months ago #241627 by phillc54
4 years 6 months ago #241634 by cmorley
4 years 5 months ago #242954 by ggsxx
I am trying to locate thr handler.py file but can't find it.
Time to create page: 0.124 seconds
