Touch_plate in QrDragon doesn't function as described
4 years 5 months ago #242958 by cmorley
run linuxcnc in a terminal, you'll see a line like:
..... 'Using DEFAULT handler file path:SOMEPLACE'
Copy that file to your config folder and qtvcp will use the config folder version.
In this way updates won't overwrite your modified file.
The following user(s) said Thank You: ikkuh
Time to create page: 0.052 seconds
