Tool Change Issues custom QTDragon.
- LearningLinuxCNC
- Thank you received: 39
12 May 2022 19:32 #242811
by LearningLinuxCNC
Tool Change Issues custom QTDragon. was created by LearningLinuxCNC
In my custom QTDragon UI I am running into an issue with tool changes.
I have manual tool changes working when I do a M6 T? in the MDI box. This works fine the tool change dialog pops up and prompts for the tool change to be completed. On pressing OK the tool change is completed and additional commands can be made.
Now I have a button that runs some python code in the UI. This code does not work. It stalls out and does not show the tool change dialog. Since I can't press the ok button it times out.
This is the output in the terminal.
if toolfound:
try:
#this is the code to actually drill the holes using Gcode.
ACTION.SET_MDI_MODE()
cmdstr = "M6 T" + str(toolnum)
#ACTION.CALL_MDI(cmdstr)
print ("MDI command sent " +cmdstr)
ACTION.CALL_MDI_WAIT(cmdstr, 30.0) # wait until the tool change operation is complete.
print ("MDI command completed")
cmdstr = "G43"
#self.c.mdi(cmdstr)
ACTION.CALL_MDI_WAIT(cmdstr) #wait for the tool length offset to be applied.
print ("MDI command completed")This is the output in the terminal.
('Tool description: ', '0.054 SprayballDrill ')
('Hole index:', 4)
('Hole diameter:', 0.054, 0.054)
('Tool Selected For Drilling is tool: ', 2054)
MDI command sent M6 T2054
[QtDesigner.QTVCP.QT_ACTION][DEBUG] MDI_WAIT_COMMAND= M6 T2054, maxt = 30.0 (qt_action.py:128)
[QtDesigner.QTVCP.QT_ACTION][DEBUG] MDI_COMMAND: M6 T2054 (qt_action.py:131)
[QtDesigner.QTVCP.QT_ACTION][DEBUG] MDI_COMMAND_WAIT timeout past 30.0 sec. Error: -1 (qt_action.py:135)
MDI command sent G43
[QtDesigner.QTVCP.QT_ACTION][DEBUG] MDI_WAIT_COMMAND= G43, maxt = 5 (qt_action.py:128)
[QtDesigner.QTVCP.QT_ACTION][DEBUG] MDI_COMMAND: G43 (qt_action.py:131)
- LearningLinuxCNC
12 May 2022 19:33 #242812
by LearningLinuxCNC
Replied by LearningLinuxCNC on topic Tool Change Issues custom QTDragon.
My question is why is the tool change dialog not showing up when calling the tool change from MDI_WAIT_COMMAND?
- Thank you received: 2181
13 May 2022 02:35 #242846
Replied by cmorley on topic Tool Change Issues custom QTDragon.
MDI_WAIT_COMMAND blocks the GUI code until it finishes.
The GUI code must run to pop the tool change dialog.
You could:
-use an external tool dialog
-use MDI_CALL_LiST (currently no docs for)
-use an external program to call the MDI commands (Qtvcp probing does this)
You could:
- LearningLinuxCNC
13 May 2022 14:03 #242878
by LearningLinuxCNC
Thanks for the info. I will try the subprogram route like basic_probe uses. Looks to be the best for my overall application.
Time to create page: 0.103 seconds
