A couple of errors during update 2.8.2-130-g87f66feaf
4 years 3 months ago #247609 by JohnnyCNC
Here is a zip of my config directory.
File Name: SiegX3.zip
File Size:1004.67 KB
4 years 3 months ago #247610 by dgarrett
Repeating request:
@spumco :
1) post the output from:
   $ linuxcnc_info
2) post a tar or zip file of the configuration directory
3) post details on the steps needed to produce the error
4) when the error occurs, execute (in a separate shell):
   $ halcmd show pin|grep active
and post the result
Also
4) Please try to duplicate in an included distribution sim
config (qtdragon?) and post detailed steps to reproduce the error.
4 years 3 months ago #247618 by spumco
Files attached, along with screenshot of error message.
LCNC 2.9 RIP, qtpyvcp (master), Probe Basic (py3)
Steps to reproduce:
  • Start machine & home all axis
    • jogging works
  • load ngc file
    • switch back to manual mode - jogging works
  • run ngc file using cycle start GUI button
    • file completes
  • select manual mode GUI button
    • jogging works
  • run ngc file again
    • file completes
    • attempt to jog => error message + jogging not responsive
  • close error message
    • jogging still not responsive
  • select manual mode GUI button => error message + jogging not responsive
  • select auto mode GUI button => error message + jogging not responsive
As you can see from above, the error didn't happen the first time I ran the program, but it did after the second time.  Other sessions have errored out on the 1st or later attempts.
Could not reproduce on included sim QtDragon_hd.
4 years 3 months ago - 4 years 3 months ago #247622 by dgarrett
@spumco
The ini file PBtestATC.ini contained in HAL_rev33_ATC.zip
uses:
[DISPLAY]
DISPLAY = probe_basic
The probe_basic executable is not part of the LinuxCNC
git tree or distribution and i don't have the time or
energy to build or test executables from outside projects.
Can you
1) reproduce problem using in-tree guis?
or better:
2) reproduce problem using an in-tree SIMULATION config
like qtdragon?
Ref: configs/sim/qtvcp_screens/qtdragon/qtdragon.ini
I have some ideas, but ... the hardware configs showing
the problem are complicated to test as they include
specific hardware (hm2_eth, vc-p4s) that i do not have
so simplifying to a sim config would be helpful.
Alternatively, making a modified config to test without
use of the vc-p4s component could help to isolate
the problem as it may be related to halui plus/minus
jogging implemented therein.
Last edit: 4 years 3 months ago by dgarrett.
4 years 3 months ago #247626 by spumco
[don't blame for not wanting to delve in to edge-case GUI's]
I'm unable to reproduce the error in qtdragon or qtdragon_hd sims
I turned off the vc-p4s MPG component (commented out both HALFILE and POSTGUI_HALFILE) and the error is not occurring, regardless how many times I run an NGC file and switch back and forth between manual/auto modes.
I think that narrows it down, yes?
This wasn't an issue as of few months ago and I haven't changed anything in either of the vc-p4s hal files.
4 years 3 months ago #247627 by dgarrett
@spumco :
It appears you are running a self-built Run-in-place
install for the master branch at commit 8da3ed4f04 (Jun 9 2022)
I've made a test branch with a potential fix based
on the current master branch that you can test by
checking out and building the branch:
dgarr/master_testa
Example:
$ cd your_LinuxCNC_git_top_directory
$ git fetch
$ git checkout dgarr/master_testa
$ cd src
$ make && sudo make setuid
$ test_your_hardware_config
Please test and report
@johnnyCNC :
It appears you are running a deb install for the 2.8 branch
commit 87f66feaf (27 may 2022)
I've made a test branch dgarr/2.8testa based on current
2.8 branch that you can get from the buildbot as a 'scratch' deb
Instructions for using a scratch deb at:
buildbot.linuxcnc.org/
Time to create page: 0.182 seconds
