NGCGui for Qtvcp with autoload feature(files attached)
4 years 2 months ago #249003 by cmorley
add -d to the INI
DISPLAY = qtvcp -d qtdragon
then running from the terminal will show the logs output.
The following user(s) said Thank You: Eyecon
4 years 2 months ago #249040 by Eyecon
yes thank you, I got my self familiar with the qtvcp library so I'm not guessing what the code is trying to do :)
I just did a pull a rebuilt/installed the packages and they work beautifully!
Now if I can only figure out what qtvcp is doing to cause the segmentation fault on exit and why it seems to bog down the system! :)
4 years 2 months ago #249366 by cmorley
The ending segmentation fault might be a known problem for pyqt programs.
docs.huihoo.com/pyqt/PyQt5/gotchas.html
stackoverflow.com/questions/39107846/seg...-pyqt5-but-not-pyqt4
I can change the behavior by changing exit code functions, but not fix it yet.
4 years 2 months ago #249367 by Eyecon
Thank you that would be great although my bigger concern is why my Mesa cards keep timing out when I’m using qtdragon. I that committed a few changes to qtvcp over the last couple of feats related to error handling but I haven’t had the chance to do a pull and reinstall yet. Did you by any chance get the opportunity to test this behaviour with any of the Mesa cards?
4 years 2 months ago #249372 by tommylight
While QTDragon is running, open a terminal and type
sudo top
See what is using a lot of resources and check the system load.
4 years 2 months ago #249374 by Eyecon
It’s not a system wide issue, it’s specific to the qtvcp thread when running linuxcnc, all other UIs l(gmoccapy and probe_basic) perform fine and never had a timeout issue with them on the same machine.
Time to create page: 0.327 seconds
