qtdragon_hd development issues
4 years 1 month ago #252210 by auto-mation-assist
I have been working on the python code to interface qtdragon hd version to my milling machine and later building a custom .ui for it. My configurtaion files will need to migrate from gmoccapy requirements. It is starting to work but I'm hung up on the tool data base and can't find much info. I'm using Debian 11.
My present problem is this error:
[QTvcp][CRITICAL]  Aborted from Error Dialog
 Qtvcp encountered an error.  The following information may be useful in troubleshooting:
LinuxCNC Version  : 2.9.0~pre0
  File "/home/cnc/linuxcnc-dev/configs/QtDragon_hd/qtdragon/tool_database.py", line 99, in <lambda>
    STATUS.connect('periodic', lambda w: self.update_status())
  File "/home/cnc/linuxcnc-dev/configs/QtDragon_hd/qtdragon/tool_database.py", line 262, in update_status
    checked = self.w.tooloffsetview.get_checked_pockets()
AttributeError: 'ToolOffsetView' object has no attribute 'get_checked_pockets'
I'm thinking that this may refer to pockets in the tool data base that I have no knowledge off. There is a tool data base file but have not looked at what it contains. I do not use a auto tool loader and thus have no other potential tool pockets.
A second but minor problem that I have seen before and I think not related qtdragon :
[QTvcp.QTVCP.WIDGETS.VERSA_PROBE][DEBUG]  Saving Versa probe data to preference file. (versa_probe.py:187)
/home/cnc/linuxcnc-dev/scripts/linuxcnc: line 963: 22764 Segmentation fault      $EMCDISPLAY -ini "$INIFILE" $EMCDISPLAYARGS $EXTRA_ARGS
4 years 1 month ago #252219 by cmorley
What qtdragon_hd are you using?
The segfault in an ongoing qt issue that we have not been able to fix.
4 years 1 month ago #252225 by auto-mation-assist
Cloned it from: github.com/persei802/QtDragon_hd
I'm not sure if this source is the master.
4 years 1 month ago #252227 by cmorley
This is Jim's (The author) personal version of qtdragon_hd.
I intend to integrate it on linuxcnc after the 2.9 release.
He just added work for linuxcnc's database tool table - it's experimental.
He may see your post and help.
if you choose to use linuxcnc's version of qtdragon_hd - I can help further.
4 years 1 month ago - 4 years 1 month ago #252228 by auto-mation-assist
I actually wanted the supported linuxcnc's version of qtdragon_hd. I don't know were its hiding and my search on git hub appears to have led me to the wrong source.
Last edit: 4 years 1 month ago by auto-mation-assist.
4 years 1 month ago - 4 years 1 month ago #252229 by auto-mation-assist
I see: /configs/sim/qtvcp_screens/qtdragon/ but it does not say 'hd' and does not look complete.
Time to create page: 0.338 seconds
