qt-Dragon HD Qtvcp error
4 years 1 month ago #253135 by cspice
Hello,
I updated linuxcnc to version: 2.9.0-pre0-7921-gfdda9b21a
Now my qtDragonHD configuration does not load anymore, even if I try the sim version of QtDragon_hd it gets a Qtcvp error, the only version of qtDragon that works are the non hd sim versions.
Below is the QTvcp error message, what can be the cause of this error message?
  File "/usr/bin/qtvcp", line 511, in <module>
    APP = QTVCP()
  File "/usr/bin/qtvcp", line 277, in __init__
    window.load_extension(opts.usermod)
  File "/usr/lib/python3/dist-packages/qtvcp/qt_makegui.py", line 265, in load_extension
    methods, self[obj].handler_module, self[obj].handler_instance = self._load_handlers([handlerpath], self.halcomp, self[obj])
  File "/usr/lib/python3/dist-packages/qtvcp/qt_makegui.py", line 293, in _load_handlers
    mod = __import__(basename)
  File "/usr/share/qtvcp/screens/qtdragon_hd/qtdragon_hd_handler.py", line 18, in <module>
    from math import dist, ceil
ImportError: cannot import name 'dist' from 'math' (unknown location)
4 years 1 month ago #253136 by cmorley
Replied by cmorley on topic qt-Dragon HD Qtvcp error
It cant find a math library.
run this in a terminal:
sudo apt install python3-distutils
The following user(s) said Thank You: cspice
4 years 1 month ago #253169 by cspice
Replied by cspice on topic qt-Dragon HD Qtvcp error
I tried it but python3-distutils is already installed.
4 years 1 month ago #253181 by cmorley
Can you tell us about your linux system?
Can you yell us the python version number?
4 years 4 weeks ago #253384 by cspice
Hello sorry for the late reply, My linux system details are,
Debian 10
Kernel : Linux cnc-plasma 5.10.0-0.deb10.17-rt-amd64
Linuxcnc Version : 2.9.0-pre0-7939-g600ba1a08
Python 2 : Python 2.7.16 (default, Oct 10 2019, 22:02:15)
Python 3 : Python 3.7.3 (default, Jan 22 2021, 20:04:44)
python3-distutils version (3.7.3-1)
I missed out a part of the error message on my first post,
I don't understand why it asks me to install python3-distutils even though it is installed, is it a missing dependency?
File "/usr/share/qtvcp/screens/qtdragon_hd/qtdragon_hd_handler.py", line 19, in <module>
During handling of the above exception, another exception occurred:
APP = QTVCP()
File "/usr/share/qtvcp/screens/qtdragon_hd/qtdragon_hd_handler.py", line 21, in <module>
LOG.error('Is python distutils installed? (sudo apt install python3-distutils')
NameError: name 'LOG' is not defined
4 years 4 weeks ago #253400 by cmorley
can you open a terminal type:
python3
then:
and see if you get an error.
