2.9 Install Help
4 years 3 weeks ago #253925 by servocnc
2.9 Install Help was created by servocnc
I'm a new LinuxCNC user that's trying to work on a migration off of Mach3.  I'm good with computers and programing, but not with Linux, and I'm getting very frustrated with it - just be aware...  I've used Linux off an on over the last 20 years and like the end result, but hate getting there every time...
I used the ISO and got an instance of 2.8 working on my machine with the parallel port.  I liked QTDragon and would like to try out QTDragon HD, which requires 2.9 effectively (best I can tell).  I'll also note that I'll probably try PathPilot down the road, but I want to get things worked out with QTDragon HD first.  To assist in this move, I'll be adding a Mesa 7i92H soon, but for now I'm just trying to get the software installed / working.
So, I tried upgrading my Buster / 2.8 install to 2.9, and that failed miserably.  I had over a hundred dependencies that I couldn't figure out how to resolve, so I started looking for other options.  Here on the forum, I found the sticky for installing 2.9 on Mint ( forum.linuxcnc.org/9-installing-linuxcnc...ter-on-linux-mint-21 ), so I've tried that.
I have Mint installed, and LinuxCNC 2.9 works in Axis.  But I can't get it to work with QTDragon (any of them).  I first had errors that PYQT5 was missing, so I got that installed (sudo apt-get install python3-pyqt5).
Now, when I run LinuxCNC with any of the QTDragons, I get this error:
Traceback (most recent call last):File "/usr/bin/qtvcp", line 511, in <module>APP = QTVCP()File "/usr/bin/qtvcp", line 133, in __init__from qtvcp import qt_makepins, qt_makeguiFile "/usr/lib/python3/dist-packages/qtvcp/qt_makepins.py", line 22, in <module>from qtvcp.widgets.screen_options import ScreenOptionsFile "/usr/lib/python3/dist-packages/qtvcp/widgets/screen_options.py", line 24, in <module>from qtvcp.lib.message import MessageFile "/usr/lib/python3/dist-packages/qtvcp/lib/message.py", line 5, in <module>from qtvcp.widgets.dialog_widget import LcncDialogFile "/usr/lib/python3/dist-packages/qtvcp/widgets/dialog_widget.py", line 32, in <module>from qtvcp.widgets.macro_widget import MacroTabFile "/usr/lib/python3/dist-packages/qtvcp/widgets/macro_widget.py", line 86, in <module>class CustomSVG(QtSvg.QSvgWidget):NameError: name 'QtSvg' is not defined
When I hit "Retry", I then get the normal LinuxCNC Errors window:
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_CONFIG_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.9.0~pre0
Machine configuration directory is '/home/oem/linuxcnc/configs/sim.qtvcp_screens.qtdragon'
Machine configuration file is 'qtdragon.ini'
INIFILE=/home/oem/linuxcnc/configs/sim.qtvcp_screens.qtdragon/qtdragon.ini
VERSION=1.1
PARAMETER_FILE=qtdragon.var
TPMOD=
HOMEMOD=
TASK=milltask
HALUI=halui
DISPLAY=qtvcp qtdragon
COORDINATES=XYZ
KINEMATICS=trivkins coordinates=XYZ
Starting LinuxCNC...
Found file(REL): ./core_sim.hal
Found file(lib): /usr/share/linuxcnc/hallib/simulated_home.hal
Starting DISPLAY program: qtvcp
task: 7548 cycles, min=0.000021, max=0.014070, avg=0.010036, 0 latency excursions (> 10x expected cycle time of 0.010000s)
Debug file information:
Note: Using POSIX realtime
[QTvcp][[31mERROR[0m]  Qtvcp Error with loading webView - is python3-pyqt5.qtwebengine installed? (qtvcp:29)
[QTvcp.QTVCP.WIDGETS.MACRO_WIDGET][[41mCRITICAL[0m]  Qtvcp error with macro_widget - is package python3-pyqt5.qtsvg installed? (macro_widget.py:44)
[QTvcp][[41mCRITICAL[0m]  Retry from Error Dialog
 Qtvcp encountered an error.  The following information may be useful in troubleshooting:
LinuxCNC Version  : 2.9.0~pre0
    APP = QTVCP()
 (qtvcp:507)
21020
21054
Stopping realtime threads
Unloading hal components
I've googled as best I know how and haven't found any solutions related to LinuxCNC.  I'm sure it's something simple, but I don't know how to fix it.  Hopefully someone here does...
Thanks,
Danny
4 years 3 weeks ago #253926 by tommylight
The following user(s) said Thank You: servocnc
4 years 3 weeks ago #253927 by servocnc
Replied by servocnc on topic 2.9 Install Help
Well, made progress based on your suggestion, so thanks for that.
For newbies like me, what I did was:
cd /usr/lib/python3/dist-packages/qtvcp/designer/
sudo bash install_script
When prompted, I chose option #3 for package install (I guessed).
The base QTDragon now appears to work. But when I choose QTDragon HD, I get the QTVCP error window once it's loaded:
Traceback (most recent call last):File "/usr/lib/python3/dist-packages/qtvcp/widgets/round_gauge.py", line 54, in paintEventself.draw_zones(painter, event, w)File "/usr/lib/python3/dist-packages/qtvcp/widgets/round_gauge.py", line 84, in draw_zonesrect.setSize(QSize(w/2, w/2))TypeError: arguments did not match any overloaded call:QSize(): too many argumentsQSize(int, int): argument 1 has unexpected type 'float'QSize(QSize): argument 1 has unexpected type 'float'
And after I hit "Abort" ("Retry" doesn't change anything - the error pops right back up) then I get the normal Linux CNC error box that contains:
RUN_IN_PLACE=no
LINUXCNC_DIR=
INIVAR=inivar
HALCMD=halcmd
Machine configuration file is 'qtdragon_hd.ini'
INIFILE=/home/oem/linuxcnc/configs/sim.qtvcp_screens.qtdragon/qtdragon_hd.ini
VERSION=1.1
TPMOD=
HOMEMOD=
TASK=milltask
HALUI=halui
DISPLAY=qtvcp qtdragon_hd
COORDINATES=XYZ
task: 4270 cycles, min=0.000019, max=0.010305, avg=0.009994, 0 latency excursions (> 10x expected cycle time of 0.010000s)
[QTvcp.QTVCP.LIB.QT_PDF.PDFVIEWER][[33mWARNING[0m] PDFViwer - Is python3-poppler-qt5 installed? (PDFViewer.py:15)
[QTvcp.QTVCP.LIB.QT_NGCGUI.NGCGUI][[34mDEBUG[0m] UI Filename: /usr/lib/python3/dist-packages/qtvcp/lib/qt_ngcgui/ngcgui.ui (ngcgui.py:458)
[QTvcp.QTVCP.LIB.QT_NGCGUI.NGCGUI][[34mDEBUG[0m] UI Filename: /usr/lib/python3/dist-packages/qtvcp/lib/qt_ngcgui/ngcgui.ui Didn't find a path NGCGUI files (ngcgui.py:485)
QBackingStore::endPaint() called with active painter; did you forget to destroy it or call QPainter::end() on it?
QWidget::repaint: Recursive repaint detected
(qtvcp:507)
(qtvcp:507)
[QTvcp][[41mCRITICAL[0m] Aborted from Error Dialog
(qtvcp:503)
/usr/bin/linuxcnc: line 963: 4227 Segmentation fault (core dumped) $EMCDISPLAY -ini "$INIFILE" $EMCDISPLAYARGS $EXTRA_ARGS
4189
4223
I haven't researched this one yet, but Ifigured I'd post my progress here for future reference...
Danny
4 years 3 weeks ago #253985 by servocnc
OK, I'm stuck. I've searched and everything associated with these errors seems to be programming bugs and nothing related to LinuxCNC. Anyone have any ideas?
Danny
4 years 3 weeks ago #253989 by tommylight
Replied by tommylight on topic 2.9 Install Help
Moved to "Qtvcp" section.
Those all seem QT errors, so might get more help here.
4 years 3 weeks ago #253995 by cmorley
Replied by cmorley on topic 2.9 Install Help
This looks like it is because the latest pyqt library changed function signature types.
can you;
open a terminal and type:
python3
then:
from PyQt5.QtCore import QT_VERSION_STR, PYQT_VERSION_STR
print("Qt: v", QT_VERSION_STR, "\tPyQt: v", PYQT_VERSION_STR)
And post what it prints.
Time to create page: 0.148 seconds
