"iocontrol.0.user-enable-out" seems broken in latest 2.9 master
3 years 11 months ago #257055 by cmorley
How did you decide iocontrol.0.user-enable-out is not working?
I checked on the sim configs and it seems to work.
I don't see anything in the HAL file - other then you need an external input to complete the estop loop.
3 years 11 months ago #257067 by turbostew
Well, it never goes True. It did from master 6 months ago. I also notice that the ESTOP soft button is alway green in the middle, it used to toggle. I wonder if an external estop cycle is needed to "enable" the iocontrol.0.user-enable-out? My external estop shuts down drives and other stuff so not easily tested.
3 years 11 months ago #257069 by cmorley
Ahh I think I see the problem.
If the external estop input is high (clear) at start up it wont let you clear the GUI estop.
While I was testing, the external signal started low so i didn't see this.
Ok let me look into this.
And yes the behavior changed a while back to more closely follow AXIS's behavior.
3 years 11 months ago - 3 years 11 months ago #257073 by cmorley
ok this behavior is consistent with AXIS so seems an oddity of linuxcnc it's self.
The external enable-in pin can not be in a true state before the GUI estop pin is set true.
iocontrol.0.enable-in will ignore the gui enable-out state (unless connected via HAL)
yet gui enable-out pin will not turn high when linuxcnc is set out of estop by enable-in
Normally the GUI enable-out pin is part of the HAL estop chain, so is _always_ true before the enable-in pin gets set true. This was by design.
So if you can add estop-out to the external estop chain, this will work properly.
Said another was, the GUI button must initiate clearing the external estop chain, before estop-ext is set high.
Chris
Last edit: 3 years 11 months ago by cmorley.
The following user(s) said Thank You: arvidb
3 years 11 months ago #257174 by turbostew
Thank You Chris for all the help. Sorry, but can you be more clear what you mean when you say "you can add estop-out to the external estop chain"? What are the exact hal signal names you are referring to?
3 years 11 months ago #257190 by cmorley
Sorry it's hard to be exact as I don't know your hardware or needs.
Based on your HAL file you selected an external estop input (estop-ext)
This says to me you want external hardware to be able to estop linuxcnc.
Usually one wants to be able to estop/reset via the GUI button, but that is not the only option.
Here are some options (sim/axis/classicladder can demo these)
1) just use the gui button (no external estop)
2) just the external estop - gui button will only set the machine off or the button can be removed
3) combined gui and external -comes out of estop immediately when both are cleared
4) combined gui and external with estop reset latch - comes out of estop when both are cleared and gui button is pressed
The chain refers to the software and hardware links.
for option 1 above (standard in the sim configs):
net estop-loop iocontrol.0.user-enable-out iocontrol.0.emc-enable-in
Here is yours (I removed debounce for clarity)
net estop-out => hm2_7i92.0.7i84.0.0.output-00
net estop-ext => iocontrol.0.emc-enable-in
net estop-ext <= hm2_7i92.0.7i84.0.0.input-00
estop-out is the gui signal sent out to external logic
estop-ext is the input from the logic that actually sets linuxcnc in/out of estop
If you electrically connected hm2_7i92.0.7i84.0.0.output-00 to hm2_7i92.0.7i84.0.0.input-00 The button would work normally.
If you wanted to add a hardware estop button to this, then you would add a switch between them. In that case the gui and the hardware button must be cleared to clear linuxcnc's estop state.
What do you wish to do?
Time to create page: 0.059 seconds
