Multiple '.' not allowed in LinuxCNC
- daiman444
- Thank you received: 8
26 Nov 2022 13:21 #257680
by daiman444
Multiple '.' not allowed in LinuxCNC was created by daiman444
hi all. the question is more to qtplasmac but I checked the same in qtaxis for linuxcnc2.9:
when opening a file whose name contains two dots, for example "001. Some_cut.ngc", the file is not loaded and gives a warning: "Multiple '.' not allowed in LinuxCNC". in qtplasmac_handler.py i found:
in interfaces on qt in linuxcnc 2.8, I checked the opening of files with the same name "001. Some_cut.ngc" and everything opens there without problems.
is this a bug or feature for linuxcnc 2.9?
def file_loaded(self, obj, filename):
if os.path.basename(filename).count('.') > 1:
self.lastLoadedProgram = ' '
returnin interfaces on qt in linuxcnc 2.8, I checked the opening of files with the same name "001. Some_cut.ngc" and everything opens there without problems.
- Thank you received: 2175
26 Nov 2022 21:07 #257699
Replied by cmorley on topic Multiple '.' not allowed in LinuxCNC
It was a feature, but I don't remember why.
I tried to find the discussion on github but have failed.
26 Nov 2022 21:17 #257701
Here is the discussion:
github.com/LinuxCNC/linuxcnc/pull/1082
The following user(s) said Thank You: daiman444
- daiman444
26 Nov 2022 21:39 #257704
by daiman444
Replied by daiman444 on topic Multiple '.' not allowed in LinuxCNC
thanks for the info mate. this feature is like a big crutch like many other things, alas ((
26 Nov 2022 21:55 #257705
You could remove that check from Qtplasmac's handler file. It's also coded in one other file but I'm not sure if qtplasmac uses it.
I'll see if I can find out the specific problem.
Is there any other reason to require multiple . other then preference?
- phillc54
- Thank you received: 2100
27 Nov 2022 06:01 #257721
by phillc54
Replied by phillc54 on topic Multiple '.' not allowed in LinuxCNC
I had a bit of a play with this by removing the inhibits from qtplasmac_handler.py and qt_action.py.
I also changed name, ext = path.rsplit('.') in the qt_action save function to name, ext = path.rsplit('.', 1) which then enabled saving with multiple periods.
After this I could load, run and save files with multiple and also multiple consecutive periods without any obvious errors. This was only tested on a sim config.
Time to create page: 0.156 seconds
