QtDragon_HD Manual tool change
- Zavrl
13 Jan 2023 14:00 #261796
by Zavrl
QtDragon_HD Manual tool change was created by Zavrl
Hello,
following the instructions from chapter 10.5.6 HAL Pins, I entered the suggested code in postgui.hal. I would like to be notified when the tool needs to be changed.
Now it happens that if the command Tn or M6 is written in the G-code, the program stops and does not continue. Nowhere on the screen does a dialog box appear, for confirming that the tool has been replaced. I think the problem is that the dialog box doesn't appear.
What and where needs to be set for it to work.
- Thank you received: 2170
13 Jan 2023 19:56 #261824
Replied by cmorley on topic QtDragon_HD Manual tool change
Can you post your config files?
- Zavrl
14 Jan 2023 16:57 #261952
by Zavrl
Replied by Zavrl on topic QtDragon_HD Manual tool change
I am attaching the working CONFIG files and also the NC file. The tool limit command is commented out.
14 Jan 2023 18:13 #261963
try un commenting these lines:
# create signals for tool loading loopback
#net tool-prep-loop iocontrol.0.tool-prepare => iocontrol.0.tool-prepared
#net tool-change-loop iocontrol.0.tool-change => iocontrol.0.tool-changed
- Zavrl
15 Jan 2023 08:30 #262021
by Zavrl
I un commented it in the hal file.
Linuxcnc does not start, gives an error:
Pin 'iocontrol.0.tool-change' was already linked to signal 'tool-change-loop'
I can't find a duplicate of this part in my two HAL files.
There is a complete description of the error in the PDF attachment.
15 Jan 2023 08:50 #262022
Sorry just uncomment this one:
- Zavrl
15 Jan 2023 10:36 #262027
by Zavrl
Yes, now is working. I receive message window with information. It is smart solution, it checks the tool number which is active.and don't prompt if toll is the same.
You don't need to justify yourself, I'm very glad that the problem is solved.
I myself worked in IT for 22 years and I know this situation well.
Once again, thank you very much.
Greetings
Tibor Zavrl
Greetings
Tibor Zavrl
