Error message when closing qtplasmac
- paulsao
- Thank you received: 22
24 Jan 2023 02:40 #262792
by paulsao
Error message when closing qtplasmac was created by paulsao
Today I did an update of qtplasmac and I have this error maybe someone has the same as me.
Spaceship ohmic hall warning file contains DOS-sty
- snowgoer540
- Thank you received: 907
24 Jan 2023 12:40 #262814
by snowgoer540
Assuming that the rest of your error is that the hal file contains DOS-style line endings, then the solution is easy. Open the .hal file in Geany (document > set line endings) and change the line ending type to Linux and save.
Replied by snowgoer540 on topic Error message when closing qtplasmac
The following user(s) said Thank You: paulsao
- paulsao
24 Jan 2023 15:13 - 24 Jan 2023 15:29 #262819
by paulsao
Replied by paulsao on topic Error message when closing qtplasmac
Thanks for the help, now this is the new message.I don't know if it's a coincidence or not, but yesterday morning everything is normal and after updating I had problems in the afternoon with the ohmic sensor, related to height and distances, even halfway through the cut, the float switch is activated.
Last edit: 24 Jan 2023 15:29 by paulsao.
- snowgoer540
24 Jan 2023 15:37 #262820
by snowgoer540
Really need to see the entire error message
- paulsao
24 Jan 2023 16:10 #262821
by paulsao
thanks
- snowgoer540
24 Jan 2023 16:30 #262822
by snowgoer540
it appears to be something with qtvcp.
Can you try changing in the [DISPLAY] section the DISPLAY = qtvcp line to DISPLAY = qtvcp -i, running it again and getting the new error report?
- Thank you received: 4149
24 Jan 2023 20:25 #262831
Replied by rodw on topic Error message when closing qtplasmac
On your screen dump, there is a icon that says Debian 11 which is BUllseye and your kernel is 4.19 which is buster.
What version of debian are you running?
Can you share the output from
lsb_release -a
- paulsao
24 Jan 2023 22:28 #262838
by paulsao
lsb_release -a
No LSB modules are available.
Distributor ID: Debian
Description: Debian GNU/Linux 10 (buster)
Release: 10
Codename: buster
Release: 10
Codename: buster
- paulsao
24 Jan 2023 22:33 #262839
by paulsao
- phillc54
- Thank you received: 2100
24 Jan 2023 23:08 #262841
by phillc54
Replied by phillc54 on topic Error message when closing qtplasmac
Can you successfully run the standard QtPlasmaC sim?
Time to create page: 1.098 seconds
