Error message when closing qtplasmac
  • paulsao
  • paulsao's Avatar Topic Author
  • Elite Member
  • Elite Member
24 Jan 2023 23:26 #262842 by paulsao
Replied by paulsao on topic Error message when closing qtplasmac
Can you successfully run the standard QtPlasmaC sim?
Qtplasmac works fine, the only thing that happens is that when closing I get that error message, I didn't have it until yesterday morning :(.
24 Jan 2023 23:39 #262843 by snowgoer540
Replied by snowgoer540 on topic Error message when closing qtplasmac
I see what you are talking about in my terminal as well with both package and run in place.
<__main__.QTVCP object at 0x7fdd11f992b0>
I do know that Chris was working on some stuff to prevent segfaults. I wonder if this is related.
I think I will move this thread over to QTVCP so he sees is, unless someone objects?
24 Jan 2023 23:48 - 24 Jan 2023 23:56 #262845 by snowgoer540
Actually, it looks like maybe its from a debug print left in.
Let me see if I can track it down...
EDIT:  It is from this commit:  github.com/LinuxCNC/linuxcnc/commit/5d05...80a914ca8d6881a8e4a1
Prior to that commit I get no "error" on shutdown in the terminal, after that, I get the following:
<__main__.QTVCP object at 0x7fa9064912e8>
task: 523 cycles, min=0.000001, max=0.020910, avg=0.010125, 0 latency excursions (> 10x expected cycle time of 0.010000s)
Note: Using POSIX non-realtime
LinuxCNC terminated with an error.  You can find more information in the log:
    /home/plasma/linuxcnc_debug.txt
and
    /home/plasma/linuxcnc_print.txt
as well as in the output of the shell command 'dmesg' and in the terminal
Running Buster 10 (MX Linux 19.4)
Last edit: 24 Jan 2023 23:56 by snowgoer540.
24 Jan 2023 23:57 #262846 by snowgoer540
Moved the thread to qtvcp so Chris would see it :)
The following user(s) said Thank You: paulsao
25 Jan 2023 03:27 #262853 by cmorley
Replied by cmorley on topic Error message when closing qtplasmac
I'm stumped on how to fix this.
There isn't really an error (well in this case I'm assuming it's the usual segfault).
It is known problem with pyqt, that seems to be in this case sensitive to exiting HAL (which is the part I added back)
I'm open to ideas from coding experts.
Chris
  • paulsao
  • Elite Member
  • Elite Member
25 Jan 2023 16:34 #262889 by paulsao
Chris
Thanks for the help, hopefully I can fix that :)
25 Jan 2023 23:36 #262911 by snowgoer540
Chris
I'm a bit confused since normally the segfault "errors" show up on versions greater than Buster.
Both paulsao and I are running Buster, which seemed to be previously immune from this (I thought anyways).
Otherwise, I am out of ideas, it's probably way above my pay grade.
27 Jan 2023 22:44 #263032 by snowgoer540
Maybe this wasn't above my pay grade after all...
Made some headway, Chris pushed this fix: github.com/LinuxCNC/linuxcnc/commit/4683...968022550a6395c38ff4
Should be improved, but report back if it isnt!
28 Jan 2023 11:29 #263070 by rodw
Replied by rodw on topic Error message when closing qtplasmac
I can't see anything has changed in that commit. All I could see was an additional logging call.
what does LOG.debug do?
28 Jan 2023 14:44 - 28 Jan 2023 14:45 #263088 by snowgoer540
It's at the very bottom. Changed sys.exit(_qtvcp) to sys.exit(_app)
github.com/LinuxCNC/linuxcnc/blob/8890c4.../qtvcp/qtvcp.py#L509
Line 427: LOG.debug('Exiting HAL')
It passes the string following it ('Exiting HAL') to the logger at the level indicated (debug in this case, the levels are: debug, info, warning, error, critical, verbose).
Worth noting - the default level is "warning", so you will only see log messages at warning level and above in the terminal. If you want to see lower than that, you can use a one of the options that is set in the display section of the ini file after "qtvcp".
DISPLAY = qtvcp -d qtplasmac
Would set logging to the debug level for qtplasmac.
Last edit: 28 Jan 2023 14:45 by snowgoer540.
Time to create page: 0.133 seconds
