Customized QtDragon Discussion
28 Jan 2023 20:33 - 28 Jan 2023 21:04 #263118 by cmorley
Customized QtDragon Discussion was created by cmorley
 Some trial work on a customized Qtdragon with a sliding splitter pane.Also has gcode text zoom buttons in settings  The attachment holds the folders/files needed to be added to the config file inside the qtvcp folder. There should already be a qtvcp folder in your config. This will add a screens folder with qtdragon inside it.
Last edit: 28 Jan 2023 21:04 by cmorley. Reason: File too big
29 Jan 2023 11:27 - 29 Jan 2023 11:27 #263163 by MarkoPolo
Replied by MarkoPolo on topic Customized QtDragon Discussion
I like it, a few details need to be worked out and it can be.
It even remembers after restarting qtdragon how some sections should be set, e.g. file yes, settings no
Last edit: 29 Jan 2023 11:27 by MarkoPolo.
29 Jan 2023 18:22 #263174 by cmorley
Replied by cmorley on topic Customized QtDragon Discussion
Yes it records it in a private setting file. there are some situations ie when the jog area is hidden that is not recorded as the code doesn't call the settings saving loading code.
So that could be improved.
So would you say this is something that should be included by default?
Also I imagine qtdragon_hd could also use this. maybe less so as the screen area is already bigger.
29 Jan 2023 20:36 #263184 by MarkoPolo
Yes, I think it would be possible to introduce such an arrangement at this stage.
A few things do not fit into the minimum size of the main window, but such small things will be happy to improve.
There is also a static size of the line number space in the gcode field and it does not fit with a larger font.
30 Jan 2023 23:32 #263277 by MarkoPolo
I made some tweaks with better button matching.
There is also some error after pressing the "user" button several times.
31 Jan 2023 07:17 #263304 by cmorley
Thanks. I'll have an update tomorrow night.
01 Feb 2023 13:49 - 02 Feb 2023 02:28 #263441 by cmorley
This will require the latest 2.9/master code.User button fixed.splitter can be set differently in Manual/MDI or auto.
Last edit: 02 Feb 2023 02:28 by cmorley. Reason: File were wrong ..see below
01 Feb 2023 18:44 #263456 by MarkoPolo
It looks like these are the same files you shared before, they are no different
02 Feb 2023 02:27 #263485 by cmorley
Sorry I'll try again..
02 Feb 2023 08:57 #263503 by MarkoPolo
Yes, now it works properly, the function of the "user" button is ok.
Time to create page: 0.895 seconds
