QTDragon MDI jogging strange - diagonals
3 years 8 months ago #265632 by cmorley
I have found the problem line of code.. working on the best solution.
3 years 8 months ago #265633 by cmorley
In case your interested:
In mdi_line.py the display is reloaded when MDI commands are run.
During reloading the display, the task_plan_synch() is called, seemingly out of order.
Probably gets called before the MDI finishes, so old positions are used to update.
The following user(s) said Thank You: eduard
3 years 8 months ago #265634 by cmorley
Ok I pushed a hopeful fix to 2.9 and master.
Please let me know if it fixes things for you.
3 years 8 months ago #265637 by frayja2002
Hi there
As said in the initial post I'm using buildbot (2.10)
Should I be seeing an update. When I try to do an update it tells me all packages are up to date.
Will this normally come through prity quickly.
Alex
3 years 8 months ago #265640 by phillc54
It will take a while, master (2.10) is still building the debs from the previous commit.
buildbot.linuxcnc.org/buildbot/grid
3 years 8 months ago #265643 by frayja2002
Hi all
I have done an update to
LINUXCNC - 2.10.0-pre0-929-ga1380a39d
and it still seems to be doing the same thing.
Alex
Time to create page: 0.222 seconds
