Newbie question - qtdragon
- Drillbit
- Thank you received: 3
12 Mar 2023 10:05 #266478
by Drillbit
Newbie question - qtdragon was created by Drillbit
How do you set the spindle speed manually in qtdragon?
I think I'm missing something obvious.
Thank you.
Thank you.
- persei8
- Thank you received: 133
12 Mar 2023 14:27 #266492
by persei8
Replied by persei8 on topic Newbie question - qtdragon
There is no specific control for that, but you can use MDI mode.
M3 Sxxx where xxx is speed in RPM
- Thank you received: 2181
14 Mar 2023 01:48 - 14 Mar 2023 01:51 #266628
Replied by cmorley on topic Newbie question - qtdragon
If you prefer using the spindle buttons to adjust the manual spindle speed too,
try adding these lines to your stylesheet:
#action_spindle_fwd{
qproperty-spindle_up_action: true;
#action_spindle_rev{
qproperty-spindle_down_action: true;
Last edit: 14 Mar 2023 01:51 by cmorley.
- Drillbit
14 Mar 2023 20:04 - 14 Mar 2023 20:05 #266693
by Drillbit
Replied by Drillbit on topic Newbie question - qtdragon
Wil try the spindle style sheet as well but have a different question.
The spindle rpm always shows zero.
I setup the config using the tool.
Using the 7i96s voltage divider for managing spindles. Set it to be pmw
Mapped 5v to 20000.
When I type M3 s1000 the UI does not change, stays at zero. So I assume I need a line in the custom.hal file to map something.
Mapped 5v to 20000.
Last edit: 14 Mar 2023 20:05 by Drillbit. Reason: Typo
- persei8
14 Mar 2023 21:10 - 14 Mar 2023 21:16 #266704
by persei8
Note that setting those properties only works in Manual mode.
I also find it more useful if you set the button's auto repeat property in designer.
In your postgui hal file, you need to connect the spindle speed signal to the spindle rpm gauge. Something like:
net spindle-rpm qtdragon.gauge_spindle_value <= spindle.0.speed-out-abs
Your net names may be slightly different, but that's the idea.
Jim
Last edit: 14 Mar 2023 21:16 by persei8. Reason: auto repeat
