MDI calls from qtvcp
24 Apr 2023 08:29 #269737 by cmorley
Replied by cmorley on topic MDI calls from qtvcp
thank you for your responses. the actions from qtvcp are based on the actions of linuxcnc.py and inherit all of its problems and even multiply them in some cases. in view of which the actions from qtvcp do not simplify the task in any way.
the code that I need to execute is just "G0X2000Y6000" so that the portal goes to the end of the working field
You'll have to give specifics why the action library doesn't work for you. it is specifically made to make things easier, consistent and future proof.
Your code example does more then call an MDI code.ACTION.CALL_MDI('G0 X2000 Y6000')
should set linuxcnc into MDI mode if it is not and then run the command to the end without blocking.
26 Apr 2023 13:39 #269978 by daiman444
Replied by daiman444 on topic MDI calls from qtvcp
You could try something like this:
while not STATUS.is_interp_idle():
self.w.gcodegraphics.updateGL()
    QApplication.processEvents()
You are the best!
Time to create page: 0.499 seconds
