AxisToolButton help
- Thank you received: 7488
30 Jun 2023 21:28 #274539
Replied by tommylight on topic AxisToolButton help
Merged together.
- vedatech
- Thank you received: 3
30 Jun 2023 22:23 #274549
by vedatech
Replied by vedatech on topic AxisToolButton help
Thanks, sorry to cause a problem
- vedatech
03 Jul 2023 18:34 #274707
by vedatech
Thanks for the guidance. I do have screenoption widget with calculatorDialog_option and entryDialog_option set but I still can't get the behavior I want. I would like to have a separate 'set' button for each axis. When the AxisToolButton properties are set to ENTRY with a joint number -1 it will set the selected axis but if I set the joint number to a specific joint such as 0 I get no action. Is this the wrong widget for what I want?
- Thank you received: 2181
03 Jul 2023 20:30 #274712
Replied by cmorley on topic AxisToolButton help
You probably need to set the joint number and the axis letter.
Can you run a qtdragon sim config. is the axis setting system there, similar to what you want?
- vedatech
03 Jul 2023 21:35 #274713
by vedatech
I did try setting the joint number and axis letter in various combinations. I got it to work once but couldn't replicate it. I will look at qtdragon.
Time to create page: 0.373 seconds
