Fresh install of qtdragon fails
- frayja2002
- Thank you received: 13
16 Jul 2023 04:13 #275561
by frayja2002
Fresh install of qtdragon fails was created by frayja2002
Hi all
I have just done a fresh install of Linuxcnc 2.8 & then upgraded it using buildbot.
Now when I start linuxcnc from the command line it reports 2.10.0.xxxxx
I have run the stepconf wizard to create a generic starting profile & when I try to open it it crashes giving some sort of QT/python error that I don't understand.
I have attached the errorrs.
I'm sure this must be something obvious but not sure what I need.
Alex
PS cannot attach the linuxcnc generated error report !?!
Here it is pasted...
Error report created by /usr/lib/tcltk/linuxcnc/show_errors.tcl:
Debug file information:
Note: Using POSIX realtime
link (updating variable file): No such file or directory
[QTvcp.QTVCP.QT_ISTAT][[33mWARNING[0m] INI Parsing Error, No DEFAULT_SPINDLE_0_SPEED Entry in DISPLAY, Using: 200 (qt_istat.py:532)
[QTvcp.QTVCP.QT_ISTAT][[33mWARNING[0m] INI Parsing Error, No MIN_SPINDLE_0_SPEED Entry in DISPLAY, Using: 100 (qt_istat.py:532)
[QTvcp.QTVCP.QT_ISTAT][[33mWARNING[0m] INI Parsing Error, No MAX_SPINDLE_0_SPEED Entry in DISPLAY, Using: 2500 (qt_istat.py:532)
[QTvcp.QTVCP.QT_ISTAT][[33mWARNING[0m] INI Parsing Error, No MAX_SPINDLE_0_OVERRIDE Entry in DISPLAY, Using: 1 (qt_istat.py:532)
[QTvcp.QTVCP.QT_ISTAT][[33mWARNING[0m] INI Parsing Error, No MIN_SPINDLE_0_OVERRIDE Entry in DISPLAY, Using: 0.5 (qt_istat.py:532)
[QTvcp.QTVCP.QT_MAKEGUI][[41mCRITICAL[0m] Module 'qtdragon_handler' skipped - import error: (qt_makegui.py:301)
File "/usr/lib/python3/dist-packages/qtvcp/qt_makegui.py", line 296, in _load_handlers
mod = __import__(basename)
File "/usr/share/qtvcp/screens/qtdragon/qtdragon_handler.py", line 3, in <module>
from PyQt5.QtWebEngineWidgets import QWebEnginePage
ModuleNotFoundError: No module named 'PyQt5.QtWebEngineWidgets'
[QTvcp][[41mCRITICAL[0m] Aborted from Error Dialog
Qtvcp encountered an error. The following information may be useful in troubleshooting:
LinuxCNC Version : 2.10.0-pre0-1679-g39a082c79
File "/usr/bin/qtvcp", line 518, in <module>
_qtvcp = QTVCP()
File "/usr/bin/qtvcp", line 261, in __init__
window.load_extension(opts.usermod)
File "/usr/lib/python3/dist-packages/qtvcp/qt_makegui.py", line 268, in load_extension
methods, self[obj].handler_module, self[obj].handler_instance = self._load_handlers([handlerpath], self.halcomp, self[obj])
Alex
_qtvcp = QTVCP()
- Thank you received: 2181
16 Jul 2023 04:51 #275563
Replied by cmorley on topic Fresh install of qtdragon fails
try installing the library python3-pyqt5.qtwebengine
- frayja2002
16 Jul 2023 05:40 #275565
by frayja2002
Replied by frayja2002 on topic Fresh install of qtdragon fails
Yep that did the trick.
If its not part of the automatic dependencies would it be possible to get this put on the qtdragon doc page?
Alex
Alex
16 Jul 2023 05:44 #275566
The dependency list has an old library (my system has both libraries so I didn't notice)
I am looking to update the dependency and also have changed QtDragon to not crash if the library is missing - it's just for the HTML setup page.
Sorry about the trouble - thanks for the report.
Time to create page: 0.511 seconds
