Logger' object has no attribute 'INFO'
  • mariusl
  • mariusl's Avatar Topic Author
  • Platinum Member
  • Platinum Member
21 Sep 2023 06:34 - 21 Sep 2023 06:40 #281281 by mariusl
Hi
I am using versa_probe with Gmoccapy on a master config. This error comes up on almost every action.
Is there something that I have to set?
Traceback (most recent call last):File "/usr/lib/python3/dist-packages/qtvcp/widgets/versa_probe.py", line 307, in read_stderrorself.parse_input(line)File "/usr/lib/python3/dist-packages/qtvcp/widgets/versa_probe.py", line 323, in parse_inputif LOG.getEffectiveLevel() < LOG.INFO:AttributeError: 'Logger' object has no attribute 'INFO'
Regards
Marius
www.bluearccnc.com
Last edit: 21 Sep 2023 06:40 by mariusl.
21 Sep 2023 13:34 - 21 Sep 2023 13:36 #281307 by cmorley
Replied by cmorley on topic Logger' object has no attribute 'INFO'
You could change the < LOG.INFO to < 20
In versa_probe.py
And I'll try to get to thecreal fix tonight. Weird that it dirsntverrorclike that in qtdragon.
Last edit: 21 Sep 2023 13:36 by cmorley.
21 Sep 2023 13:44 #281309 by Aciera
Replied by Aciera on topic Logger' object has no attribute 'INFO'
should INFO not be lowercase?
LOG.info
21 Sep 2023 13:46 #281311 by cmorley
No thatcteferences the info function rather the the info integer. It tried it.
For whatever reason LOG object doesn't have the log level variables defined.
21 Sep 2023 13:47 #281312 by cmorley
Importing logging andxthen usingvlogging.INFO works
  • mariusl
  • Platinum Member
  • Platinum Member
21 Sep 2023 13:58 #281314 by mariusl
Replied by mariusl on topic Logger' object has no attribute 'INFO'
LOG.info
Tried that already/ It gives some other error.
Regards
Marius
www.bluearccnc.com
23 Sep 2023 01:15 #281415 by cmorley
I pushed a fix for this.
The following user(s) said Thank You: mariusl
Time to create page: 0.438 seconds
