Problems to install QT Designer. Please help.
- kig23
09 Oct 2023 08:04 - 09 Oct 2023 08:10 #282592
by kig23
Problems to install QT Designer. Please help. was created by kig23
I just installed lunuxcnc using LinuxCNC 2.8.4 Debian 10 Buster PREEMPT-RT ISO. I tried to follow the guide how to use qtvcp, but I was unable to install qt designer. I used the command:
sudo apt-get install qttools5-dev-tools qttools5-dev libpython3-dev
to install qt designer, but doesn't install these packages. Maybe the guide i use refers to an older version of linuxcnc. Maybe these packages are not available or have other names in the version 2.8.4.
Last edit: 09 Oct 2023 08:10 by kig23.
- Thank you received: 7488
09 Oct 2023 11:38 #282601
Replied by tommylight on topic Problems to install QT Designer. Please help.
- kig23
09 Oct 2023 12:08 #282608
by kig23
Replied by kig23 on topic Problems to install QT Designer. Please help.
Thanks for your replay.
- kig23
09 Oct 2023 13:48 #282612
by kig23
No luck to install QT Designer. I've tried the install script, but gives me error no packages qttools5-dev and qttools5-dev-tools. Maybe i should use older version of linuxcnc. I'm using 2.8.4. Any help is appreciated.
- Thank you received: 4149
09 Oct 2023 16:00 - 09 Oct 2023 16:01 #282623
Replied by rodw on topic Problems to install QT Designer. Please help.
I think you need to be running v 2.9 on Bookworm
Last edit: 09 Oct 2023 16:01 by rodw.
- kig23
09 Oct 2023 16:14 #282628
by kig23
thanks for your replay. The problem was a missing repository. Solved
Time to create page: 0.111 seconds
