[SOLVED] QtDragon_hd - Probe tab crashing
15 Oct 2023 11:59 - 31 Oct 2023 14:29 #283056 by karnalta
Hello all,
I am trying to activate versaprobe screen in QtDragon_hd but as soon as I click on the probe tab button, I got the following error then the UI crash.
I use Debian 12 and my python version is 3.11b.
Last edit: 31 Oct 2023 14:29 by karnalta.
15 Oct 2023 12:50 #283068 by cmorley
Replied by cmorley on topic QtDragon_hd - Probe tab crashing
There isn't quite enough infor to do any investigation. If you run linuxcnc from a terminal, there will be a longer error message.
How did you get linuxcnc? From an official Debian package?
15 Oct 2023 14:13 #283072 by karnalta
Replied by karnalta on topic QtDragon_hd - Probe tab crashing
Yes from the default sources of Debian 12. When I get back to home, I will try to start it from terminal to give you more info.
15 Oct 2023 14:57 #283078 by karnalta
I can continue if I choose "retry", the error occur four times when loading the 4 last buttons ("tool measure", "auto skew", "auto zero", "versaprobe help"). After this, I can use the module except if I pass the cursor over one of these four buttons where I instantly get the error message.
Here is what I've got from the terminal output :
[QTvcp.QTVCP.QT_ISTAT][WARNING]  INI Parsing Error, No PROGRAM_PREFIX Entry in DISPLAY, Using: ~/linuxcnc/nc_files (qt_istat.py:515)
[QTvcp.QTVCP.QT_ISTAT][WARNING]  INI Parsing Error, No MAX_SPINDLE_0_OVERRIDE Entry in DISPLAY, Using: 1 (qt_istat.py:515)
[QTvcp.QTVCP.QT_ISTAT][WARNING]  INI Parsing Error, No MIN_SPINDLE_0_OVERRIDE Entry in DISPLAY, Using: 0.5 (qt_istat.py:515)
No section: 'VERSA_PROBE_OPTIONS'
Adding section VERSA_PROBE_OPTIONS
No option 'ps_probevel' in section: 'VERSA_PROBE_OPTIONS'
No option 'ps_z_clearance' in section: 'VERSA_PROBE_OPTIONS'
No option 'ps_probe_max' in section: 'VERSA_PROBE_OPTIONS'
No option 'ps_probe_latch' in section: 'VERSA_PROBE_OPTIONS'
No option 'ps_probe_diam' in section: 'VERSA_PROBE_OPTIONS'
No option 'ps_xy_clearance' in section: 'VERSA_PROBE_OPTIONS'
No option 'ps_side_edge_length' in section: 'VERSA_PROBE_OPTIONS'
No option 'ps_probe_height' in section: 'VERSA_PROBE_OPTIONS'
No option 'ps_block_height' in section: 'VERSA_PROBE_OPTIONS'
No option 'use_tool_measurement' in section: 'VERSA_PROBE_OPTIONS'
No option 'ps_offs_x' in section: 'VERSA_PROBE_OPTIONS'
No option 'ps_offs_y' in section: 'VERSA_PROBE_OPTIONS'
No option 'ps_offs_z' in section: 'VERSA_PROBE_OPTIONS'
No option 'ps_offs_angle' in section: 'VERSA_PROBE_OPTIONS'
No option 'ps_probe_rapid_vel' in section: 'VERSA_PROBE_OPTIONS'
QBackingStore::endPaint() called with active painter; did you forget to destroy it or call QPainter::end() on it?
17 Oct 2023 00:53 #283147 by cmorley
The official Debian version of linuxcnc is very behind and kinda buggy.
If you can get the buildbot version that should fix it
17 Oct 2023 13:51 #283180 by karnalta
I have try on a simulation VM with LinuxCNC 2.9.0-35 and it solved the issue.
So I guest it will also work with the real machine.
Thank you.
Time to create page: 0.156 seconds
