[SOLVED] Disabling buttons ?
- karnalta
- Thank you received: 11
29 Oct 2023 16:31 - 31 Oct 2023 14:28 #284046
by karnalta
[SOLVED] Disabling buttons ? was created by karnalta
Hello all,
I was wondering if there is a way to disable some buttons in QtDragon UI for features my machine doesn't have.
Like "Flood", "Laser", ...
Thank you.
Thank you.
Last edit: 31 Oct 2023 14:28 by karnalta.
- Thank you received: 2181
29 Oct 2023 17:16 #284054
Replied by cmorley on topic Disabling buttons ?
disable or remove?
Either is possible but it will take a bit of effort as it requires customization of the screen.
- karnalta
29 Oct 2023 17:33 #284056
by karnalta
Replied by karnalta on topic Disabling buttons ?
Simply disable them is good. Just grey them out.disable or remove?
30 Oct 2023 07:30 #284104
Try this to hide the buttons.
add the file to your config folder and add this under the [DISPLAY] heading in the INI:
USER_COMMAND_FILE = CONFIGFOLDER/qtdragonrc.py
removing the INI line will restore the buttons.
- karnalta
31 Oct 2023 09:25 #284161
by karnalta
Hello, I've got an error when trying this.Try this to hide the buttons.
User command file for button hiding found
[QTvcp.QTVCP.QT_MAKEGUI][ERROR] No module named 'qtdragon_handler' (qt_makegui.py:361)
File "/usr/lib/python3/dist-packages/qtvcp/qt_makegui.py", line 359, in call_user_command_
exec(compile(open(rcfile, "rb").read(), rcfile, 'exec'),local)
File "/home/dimitri/linuxcnc/configs/KCNC/qtdragonrc.py", line 5, in <module>
import qtdragon_handler as SELF
ModuleNotFoundError: No module named 'qtdragon_handler'Please Log in or Create an account to join the conversation.
31 Oct 2023 12:36 #284178
can you post your config files?
- karnalta
31 Oct 2023 13:23 #284183
by karnalta
Here is my full INI :
# Generated by PNCconf at Mon Oct 9 11:04:54 2023
# Using LinuxCNC version: Master (2.9)
# overwritten when you run PNCconf again
[EMC]
MACHINE = KCNC
DEBUG = 0
VERSION = 1.1
[DISPLAY]
DISPLAY = qtvcp qtdragon_hd
PREFERENCE_FILE_PATH = CONFIGFOLDER/qtdragon.pref
POSITION_OFFSET = RELATIVE
POSITION_FEEDBACK = ACTUAL
MAX_FEED_OVERRIDE = 1.300000
MAX_SPINDLE_OVERRIDE = 1.200000
MIN_SPINDLE_OVERRIDE = 0.500000
DEFAULT_SPINDLE_0_SPEED = 24000
SPINDLE_INCREMENT = 1000
MIN_SPINDLE_0_SPEED = 12000
MAX_SPINDLE_0_SPEED = 24000
MAX_SPINDLE_POWER = 1500
MAX_SPINDLE_0_OVERRIDE = 1.0
MIN_SPINDLE_0_OVERRIDE = 0.5
INCREMENTS = Continuous, 5mm 1mm .5mm .1mm .05mm .01mm .005mm
MAX_LINEAR_VELOCITY = 60.000000
MIN_LINEAR_VELOCITY = 0.500000
DEFAULT_LINEAR_VELOCITY = 40.000000
EDITOR = gedit
GEOMETRY = xyz
CYCLE_TIME = 100
INTRO_TIME = 2
[FILTER]
PROGRAM_EXTENSION = .ngc .cam
png = image-to-gcode
gif = image-to-gcode
jpg = image-to-gcode
py = python
[TASK]
TASK = milltask
CYCLE_TIME = 0.010
[PROBE]
USE_PROBE = versaprobe
[VERSA_TOOLSETTER]
X = 28.5
Y = 27.5
Z = -40
Z_MAX_CLEAR = -2
MAXPROBE = 20
[CHANGE_POSITION]
X = 170
Y = 20
Z = -5
[PYTHON]
PATH_APPEND = ~/linuxcnc/nc_files/examples/remap_lib/python-stdglue/python
TOPLEVEL = ~/linuxcnc/nc_files/examples/remap_lib/python-stdglue/python/toplevel.py
[RS274NGC]
PARAMETER_FILE = linuxcnc.var
RS274NGC_STARTUP_CODE = G21 G40 G90 G94 G97 G64 P0.025
SUBROUTINE_PATH = ~/linuxcnc/nc_files/examples/remap-subroutines:~/linuxcnc/nc_files/examples/remap_lib
REMAP=M6 modalgroup=6 prolog=change_prolog ngc=qt_auto_probe_tool epilog=change_epilog
[EMCMOT]
EMCMOT = motmod
COMM_TIMEOUT = 1.0
SERVO_PERIOD = 2000000
[HMOT]
# **** This is for info only ****
CARD0=hm2_7i96s.0
[HAL]
HALUI = halui
HALFILE = KCNC.hal
HALFILE = KCNC-IO.hal
HALFILE = custom.hal
POSTGUI_HALFILE = custom_postgui.hal
SHUTDOWN = shutdown.hal
[KINS]
JOINTS = 3
KINEMATICS = millkins
[TRAJ]
COORDINATES = XYZ
LINEAR_UNITS = mm
ANGULAR_UNITS = degree
DEFAULT_LINEAR_VELOCITY = 2.50
MAX_LINEAR_VELOCITY = 40.00
POSITION_FILE = position.txt
[EMCIO]
EMCIO = io
CYCLE_TIME = 0.100
TOOL_TABLE = tool.tbl
TOOL_CHANGE_QUILL_UP = 1
[AXIS_X]
MAX_VELOCITY = 60.0
MAX_ACCELERATION = 350.0
MIN_LIMIT = 0
MAX_LIMIT = 355.0
[JOINT_0]
TYPE = LINEAR
HOME = 345.0
FERROR = 1.0
MIN_FERROR = 0.25
MAX_VELOCITY = 60.0
STEPGEN_MAXVEL = 75.00
STEPGEN_MAXACCEL = 480.00
P = 1000.0
I = 0.0
D = 0.0
FF0 = 0.0
FF1 = 1.0
FF2 = 0.0
BIAS = 0.0
DEADBAND = 0.0
MAX_OUTPUT = 0.0
# these are in nanoseconds
DIRSETUP = 10000
DIRHOLD = 10000
STEPLEN = 5000
STEPSPACE = 5000
STEP_SCALE = 199.8
MIN_LIMIT = -1.000
MAX_LIMIT = 355.0
HOME_OFFSET = 355.000000
HOME_SEARCH_VEL = 5.000000
HOME_LATCH_VEL = -2.492522
HOME_IGNORE_LIMITS = YES
HOME_SEQUENCE = 1
[AXIS_Y]
MAX_VELOCITY = 60.0
MIN_LIMIT = 0.000
MAX_LIMIT = 263.0
[JOINT_1]
TYPE = LINEAR
HOME = 10.0
FERROR = 1.0
MIN_FERROR = .25
MAX_VELOCITY = 60.0
STEPGEN_MAXACCEL = 480.50
P = 1000.0
I = 0.0
D = 0.0
FF0 = 0.0
FF1 = 1.0
FF2 = 0.0
BIAS = 0.0
DEADBAND = 0.0
MAX_OUTPUT = 0.0
DIRSETUP = 10000
DIRHOLD = 10000
STEPLEN = 5000
STEPSPACE = 5000
STEP_SCALE = 200.04
MIN_LIMIT = -1.000
MAX_LIMIT = 263.0
HOME_OFFSET = -1.000000
HOME_SEARCH_VEL = -5.000000
HOME_LATCH_VEL = 2.439024
HOME_SEQUENCE = 1
[AXIS_Z]
MAX_VELOCITY = 25.0
MIN_LIMIT = -140.0
MAX_LIMIT = 0.001
[JOINT_2]
TYPE = LINEAR
HOME = -10.0
FERROR = 1.0
MIN_FERROR = 0.25
MAX_VELOCITY = 25.0
STEPGEN_MAXVEL = 32.00
P = 1000.0
I = 0.0
D = 0.0
FF0 = 0.0
FF1 = 1.0
FF2 = 0.0
BIAS = 0.0
DEADBAND = 0.0
MAX_OUTPUT = 0.0
DIRSETUP = 10000
DIRHOLD = 10000
STEPLEN = 5000
STEPSPACE = 5000
STEP_SCALE = -200.0
MIN_LIMIT = -140.000
MAX_LIMIT = 0.001
HOME_OFFSET = 2.000000
HOME_LATCH_VEL = -2.500000
HOME_SEQUENCE = 2
[SPINDLE_0]
P = 0
I = 0
D = 0
FF0 = 1
FF1 = 0
FF2 = 0
BIAS = 0
DEADBAND = 0
MAX_OUTPUT = 2000
31 Oct 2023 13:53 #284185
Ahh you Te using dragon_hd
The file needs the reference to qtdragon changed ti qtdragon_hd
- karnalta
31 Oct 2023 14:26 #284190
by karnalta
Thank you !
Work nicely now.Ahh you Te using dragon_hd
Thank you !
Time to create page: 0.242 seconds
