- User Interfaces
- Qtvcp
- LxCNC 2.9.1 / QTDragon / Versa Probe: error Missing toolsetter setting: data_ts
- schnellmued
02 Nov 2023 15:21 #284338
by schnellmued
LxCNC 2.9.1 / QTDragon / Versa Probe: error Missing toolsetter setting: data_ts was created by schnellmued
Hello all
Iam currently switching from Windows/EstCam to linuxCNC (so iam a linuxCNC noob ) I try to get 2.9.1 with QTDragon_HD / Versa Probe running.
So far allmost everything works but when iam trying to do a "Probe Tool Setter Z Height" from probe screen i get the following error:
QTvcp.QTVCP.WIDGETS.VERSA_PROBE][INFO] Versa_Probe started with PID 6633
(versa_probe.py:298)
ERROR INFO Probe routine: Missing toolsetter setting: data_ts_max
[QTvcp.QTVCP.WIDGETS.VERSA_PROBE][INFO] Probe Process finished - exitCode 0 exitStatus 0 (versa_probe.py:311)
I googled for this error without result so i searched in the .py files...
The error occoured in:
probe_routines.py line 266:
def probe_ts_z(self):
try:
# basic sanity checks
if self.data_ts_max is None:
return'Missing toolsetter setting: data_ts_max'
For testing i changed it to:
try:
self.data_ts_max = 10 # <- set to 10 for testing ..
and the spindle moved Z-10 as excepted:
Do02 15:33: ERROR INFO Probe routine: failed: G38.4: Bewegung ohne Kontaktschließung beendet. cmd: G38.2 Z-10 F300.0
Iam running a fresh install of linuxCNC 2.9.1 (iso from www.linuxcnc.org/iso/linuxcnc_2.9.1-amd64.hybrid.iso 2 days ago..)
Did i miss some Config Option ? (attached my config Files and pasted .pref file belows b/c extension not allowed)
Touchoff parameter "max probe" is set in gui..
Thx alot,
Frank
-- qtdragon_hd_pref:
[CUSTOM_FORM_ENTRIES]
Tool to load = 0
Laser X = 100.0
Laser Y = -20.0
Sensor X = 66.0
Sensor Y = -25.0
Camera X = 10.0
Camera Y = 10.0
Work Height = 20.0
Touch Height = 4.0
Sensor Height = 4.0
Search Velocity = 40.0
Probe Velocity = 10.0
Max Probe = 5.0
Retract Distance = 1.0
Z Safe Travel = 10.0
Eoffset count = 5
External offsets = False
Reload program = False
Reload tool = False
Use keyboard = False
Use tool sensor = True
Use tool touchplate = True
Run from line = False
Use virtual keyboard = False
Use camera = False
Use alpha display mode = False
Inhibit display mouse selection = True
[PROBE OPTIONS]
Probe tool = 0
Probe diameter = 2
Probe rapid = 1000
Probe feed = 10
Probe search = 500
Probe max travel = 20
Probe max z = 2
Probe extra depth = 4
Probe step off = 2
Probe xy clearance = 5
Probe z clearance = 2
Probe edge width = 5
Calibration offset = 0
Cal x width = 0
Cal y width = 0
Cal diameter = 0
[VERSA_PROBE_OPTIONS]
ps_searchvel = 300.0
ps_probevel = 10.0
ps_z_clearance = 3.0
ps_probe_max = 20.0
ps_probe_max_z_travel = 5.0
ps_probe_latch = 2.0
ps_probe_diam = 2.0
ps_xy_clearance = 5.0
ps_side_edge_length = 60.0
ps_probe_height = 20.0
ps_block_height = 20.0
use_tool_measurement = True
ps_offs_x = 0.0
ps_offs_y = 0.0
ps_offs_z = 0.0
ps_offs_angle = 0.0
ps_probe_rapid_vel = 500.0
try:
try:
Thx alot,
Frank
Tool to load = 0
Laser X = 100.0
Laser Y = -20.0
Sensor X = 66.0
Sensor Y = -25.0
Camera X = 10.0
Camera Y = 10.0
Work Height = 20.0
Touch Height = 4.0
Sensor Height = 4.0
Max Probe = 5.0
Eoffset count = 5
Reload tool = False
Use camera = False
[PROBE OPTIONS]
Probe tool = 0
Probe diameter = 2
Probe rapid = 1000
Probe feed = 10
Probe search = 500
Probe max z = 2
Probe step off = 2
Cal x width = 0
Cal y width = 0
Cal diameter = 0
ps_probevel = 10.0
ps_probe_max = 20.0
ps_probe_diam = 2.0
ps_offs_x = 0.0
ps_offs_y = 0.0
ps_offs_z = 0.0
ps_offs_angle = 0.0
- Thank you received: 2181
02 Nov 2023 18:21 #284354
Replied by cmorley on topic LxCNC 2.9.1 / QTDragon / Versa Probe: error Missing toolsetter setting: data_ts
Looks like you missed some ini settings for the tool setter.
linuxcnc.org/docs/2.9/html/gui/qtdragon....uto_tool_measurement
The following user(s) said Thank You: schnellmued
- schnellmued
02 Nov 2023 18:57 #284357
by schnellmued
Replied by schnellmued on topic LxCNC 2.9.1 / QTDragon / Versa Probe: error Missing toolsetter setting: data_ts
Hello
Thx alot, that worked
I really got confused with the paramers in settings and utils screens, i feel like a real noob now
Frank
Frank
- User Interfaces
- Qtvcp
Time to create page: 0.237 seconds
