[SOLVED] QtDragon_hd - Workpiece probe error
- karnalta
- Thank you received: 11
05 Nov 2023 14:43 - 07 Nov 2023 16:54 #284631
by karnalta
[SOLVED] QtDragon_hd - Workpiece probe error was created by karnalta
Hello all,
I am trying to use the probing system to set my workpiece height from table (Utils -> Workpiece).
It start as it should by going at the workpiece probing location, do a first "rapid" probe and then back off and do the second "slow" probe.
And as soon as the second probe is trigger, I got a crash :
File "/usr/lib/python3/dist-packages/qtvcp/lib/auto_height/auto_height.py", line 128, in read_stdout
self.parse_input(line)
File "/usr/lib/python3/dist-packages/qtvcp/lib/auto_height/auto_height.py", line 157, in parse_input
data = json.loads(return_data[1])
IndexError: list index out of range
Am I doing something wrong ?
Thank you.
Last edit: 07 Nov 2023 16:54 by karnalta.
- Thank you received: 2154
05 Nov 2023 20:22 #284660
Replied by cmorley on topic QtDragon_hd - Workpiece probe error
You are not doing anything wrong. I'm sorry it's a bug.
What version of linuxcnc are you using?
Chris
Chris
- karnalta
06 Nov 2023 09:56 #284692
by karnalta
LinuxCNC 2.9.0-35
Replied by karnalta on topic QtDragon_hd - Workpiece probe error
No problem.You are not doing anything wrong. I'm sorry it's a bug.
Chris
LinuxCNC 2.9.0-35
07 Nov 2023 04:03 #284748
I have pushed the fix to the 2.9 repo.
I think you are using the official Debian package?
unfortunately I have no idea when that will be updated.
linuxcnc has officially released 2.9.1.
forum.linuxcnc.org/29-forum-announcement...was-no-2-9-0-release
Which might be better in the long run.
Chris
Chris
- karnalta
07 Nov 2023 12:02 #284766
by karnalta
I think it has not yet been accepted, I don't see any push from this date.
I will have to build LinuxCNC from source to get it once accepted ?
You mean you have push your fix to the LinuxCNC github repository ?I have pushed the fix to the 2.9 repo.
Chris
07 Nov 2023 12:52 #284768
I have but I'm not sure when it will be released next.
github.com/LinuxCNC/linuxcnc/commit/5fa8...0ef86b0ea74227362841
compiling source always allows you the latest code, but eventually the buildbot will catch up.
- karnalta
07 Nov 2023 14:14 #284776
by karnalta
I don't understand why I always need to download *.deb file manually and install them. Buildbot2 does not work from synaptic package manager.. But that's out of the scope of this post.
Thank you for the fix.
Just got it from the buildbot2, now it's working.I have but I'm not sure when it will be released next.
- Thank you received: 3785
07 Nov 2023 20:51 - 07 Nov 2023 20:52 #284820
Replied by rodw on topic QtDragon_hd - Workpiece probe error
Because the buildbot is not part of the official Debian Repository.
It is possible to tell apt to get the buildbot images in preference to those from Debian but its not a simple 1 line solution.
Last edit: 07 Nov 2023 20:52 by rodw.
Time to create page: 0.097 seconds
