Probing Holes QTdragon_HD basic
- Thank you received: 4150
09 Nov 2023 11:15 #284933
Probing Holes QTdragon_HD basic was created by rodw
Its been ages since I fired up my mill so I may be a bit out of date with versions.
i wanted to find the centre of a 13mm hole.
I set the diameter hint to 13mm but it was erroring just before the second probe.
I eventually worked out I had the XY setting set to 10mm so changed it to 13.
I then got the hole centre located.
I wondered if ths limit should be considered when looking for a hole? Surely the diameter hint is all thats required?
It cost me a fair bit of time so others could easilly be confused.
Maybe its been fixed.
PS. The conversational facing worked pretty well too!
- Thank you received: 2181
11 Nov 2023 00:22 #285066
Replied by cmorley on topic Probing Holes QTdragon_HD basic
Looking at the latest code diameter hint should be the right thing.
Can you give the error message?
11 Nov 2023 09:50 #285090
Replied by rodw on topic Probing Holes QTdragon_HD basic
Chris, it said something about probe not triggered innallowed distance.
It will be a while before I can do a test as i have amrather complex job to get out before I can loose my settings.
Time to create page: 0.319 seconds
