Qtdragon_HD jogging speed is constant
  • eduard
  • eduard's Avatar Topic Author
  • Premium Member
  • Premium Member
05 Jan 2024 10:34 - 05 Jan 2024 10:35 #289846 by eduard
Hi folks,
what Im I missing here?
I have the EtherCAT servo setup and working under qtdragon_hd, but the jogging speed is not what displayed. The GUI has 3000 for default and 3600 mm/min for max speed, but the servo reaching just 600/1200 mm/min.
I can set the velocity with MIN and MAX ACCELERATION in AXIS and JOINT, but the MIN/MAX VELOCITY has no visible difference.
Everithing else is working good so far.
thx
Last edit: 05 Jan 2024 10:35 by eduard.
10 Jan 2024 04:13 #290325 by cmorley
Replied by cmorley on topic Qtdragon_HD jogging speed is constant
Looks like you have settings commented out all over the place...
[DISPLAY]
MAX_LINEAR_VELOCITY = 60.00 (is 3600 mm/min)
[TRAJ]
MAX_LINEAR_VELOCITY= 60 (is 3600 mm/min)
[AXIS_N ]
MAX_VELOCITY is commented out
[JOINT_N]
MAX_VELOCITY is mostly commented out
try setting them all to 60
  • eduard
  • Premium Member
  • Premium Member
11 Jan 2024 18:15 #290441 by eduard
Replied by eduard on topic Qtdragon_HD jogging speed is constant
Thanks, I solve it. The problem was the velocity numbers was too small or too big. Working good in 200-2000 range.
Time to create page: 0.535 seconds
