VFD Toshiba VF NC3 not working
09 Mar 2024 02:44 #295491 by meme
VFD Toshiba VF NC3 not working was created by meme
File Name: qtvcp_postgui.hal
File Size:0 KB
File Name: postgui_call_list.hal
File Size:0 KB
File Name: cnc-cast.ini
File Size:3 KB
File Name: cnc-cast.hal
File Size:4 KB
Hi, this is my first LINUX CNC installation and I chose to use this interface. Thank to the guided interface I could easily connect the engine but I cannot connect the spidle VFD. I connected to the relay 1 the on-off button and the analogical speed controller 0..10 V. My electronic board is this one  . The inverted can get on but the spidle does not start working. I attach my configuration INI and HAL. Thank you for your time
09 Mar 2024 20:45 #295556 by cmorley
Replied by cmorley on topic VFD Toshiba VF NC3 not working
Can use use halmeter to check these signals while the spindle is on and off?:
spindle-cmd-rpm
spindle-pwm
The following user(s) said Thank You: meme
10 Mar 2024 03:35 - 10 Mar 2024 03:40 #295560 by meme
Replied by meme on topic VFD Toshiba VF NC3 not working
operating the spindle on halmeter
spindle-cmd-rpm: off O on 6000
spindle-pwm: off FASE on TRUE
spindle-voltage: on 0 off 0
but the spindle doesn't start
Last edit: 10 Mar 2024 03:40 by meme.
Time to create page: 0.334 seconds
