QTDragon error
24 Mar 2024 10:26 #296624 by Blume
QTDragon error was created by Blume
after install the image from linuxcnc website. I have run QTdragon and get this error.
  File "/usr/share/qtvcp/screens/qtdragon_hd/qtdragon_hd_handler.py", line 1036, in chk_use_virtual_changed
    self.w["axistoolbutton_" + i].set_dialog_code(codestring)
  File "/usr/lib/python3/dist-packages/qtvcp/qt_makegui.py", line 498, in __getitem__
    return getattr(self, item)
AttributeError: 'VCPWindow' object has no attribute 'axistoolbutton_a'
Dont know what that means.
24 Mar 2024 12:22 #296629 by cmorley
Replied by cmorley on topic QTDragon error
It's a known bug.
Can you explain how you got linuxcnc? This bug has been fixed.
In the mean time, I believe on the settings page, uncheck the 'use virtual keyboard'' option.
I think this should hide the error.
24 Mar 2024 13:16 #296634 by Blume
Replied by Blume on topic QTDragon error
Thank you.
I install the newest image from the website. Can I update qtdragon with the terminal ?
24 Mar 2024 14:11 #296639 by cmorley
Which website?
which version of linuxcnc?
Which distribution of linux?
24 Mar 2024 15:00 #296642 by Blume
linuxcnc.org/downloads/
LinuxCNC 2.9.2 Debian 12 Bookworm PREEMPT-RT ISO
24 Mar 2024 19:11 #296660 by cmorley
ok thanks that helps.
This has been fixed for 2.9.3 release which should come out relatively soon.
Then you can pull the updates in.
Time to create page: 0.160 seconds
