Change from Gmoccapy to QtDragon_hd
  • CADdy
  • CADdy's Avatar Topic Author
  • Premium Member
  • Premium Member
29 Mar 2024 09:21 #297110 by CADdy
Hi all,
I have a working configuration of LinuxCNC 2.9.2 for the Gmoccapy interface and want to switch to QtDragon_hd. The ini file was no problem. How do I bring the currently used hal file to QtDragon?  Simply copying it into the configuration folder and activating it in the ini does not work. LCNC no longer starts at all. Is there any information on how to transfer the hal or is it only possible with try and error? I would be grateful for a few tips.
Thanks a lot
Peter
29 Mar 2024 14:00 #297134 by rodw
Replied by rodw on topic Change from Gmoccapy to QtDragon_hd
Read the manual, take your time and add all of the things it says to do.
Run Linuxcnc from the command line so it reports errors. (And read them)
I moved from Axis and it wasn't too hard to get it going but took a while to conect all the fancy bits!
29 Mar 2024 15:22 #297139 by cmorley
Replied by cmorley on topic Change from Gmoccapy to QtDragon_hd
post the actual error messages plus the config files and we can help you more.
  • CADdy
  • Premium Member
  • Premium Member
29 Mar 2024 16:23 #297145 by CADdy
Replied by CADdy on topic Change from Gmoccapy to QtDragon_hd
Thank you for your answers.
@rodw: You're right, I'll read through the manual first. Besides, it was probably too late to think about it yesterday. I always start LinuxCNC from the console during configuration. Precisely because of error messages that you don't see otherwise (and I read them too  ).
@cmorley: If I get stuck because of an error, I'll get back to you with the corresponding message.
Peter
Time to create page: 0.176 seconds
