Which format is correct?
- gardenweazel
- Thank you received: 10
16 Jul 2024 19:43 #305390
by gardenweazel
Which format is correct? was created by gardenweazel
All,
I noticed that there is a variation of variable naming conventions between linuxcnc version 2.8 and the DEVEL version.
The difference I'm seeing is a hyphen and an underscore delimiting variable words.
Here's the related v2.8 docs page and the related DEVEL (2.10) docs page .
The variables that I noticed are as follows:
2.8 Versionqtdragon.modbus-errors
qtdragon.spindle_amps
qtdragon.spindle_fault
qtdragon.spindle_volts
2.10 Versionqtdragon.spindle-modbus-connection
qtdragon.spindle-modbus-errors
qtdragon.spindle-amps
qtdragon.spindle-fault
qtdragon.spindle-volts
Are these typos or a valid change?
- Thank you received: 2170
16 Jul 2024 20:15 #305397
Replied by cmorley on topic Which format is correct?
That was an intentional change.
Hyphen is the usual thing with HAL names.
The following user(s) said Thank You: gardenweazel
- gardenweazel
16 Jul 2024 20:36 #305406
by gardenweazel
Replied by gardenweazel on topic Which format is correct?
Thanks Chris!
Time to create page: 0.092 seconds
