[solved] How to set manual tool change remapping in qtdragon. Z limit error
  • SanzuiWorks
  • SanzuiWorks's Avatar Topic Author
  • Senior Member
  • Senior Member
22 Jul 2024 09:42 - 25 Jul 2024 09:29 #305860 by SanzuiWorks
I am having trouble setting up manual tool changes and remaps in QTDragon.
I'm trying to migrate from Gmoccapy, but I just can't get it to work.
I am setting it up from scratch, but currently the replacement instruction window is displayed and the tool probe and workpiece are moved.
In this state, the Z-axis height above the pre-beam appears to be about twice the maximum height.
The message reads:
invalid params in linear command error parameter is [3.000000]
Linear move on line 17 would exceed Z's negative limit
I've been doing this all day today. It seemed to work once, but I can't reproduce it. I've set it up from scratch many times, but it's stuck in the same place.
LinuxCNC2.9.3
Last edit: 25 Jul 2024 09:29 by SanzuiWorks.
22 Jul 2024 23:35 #305886 by cmorley
Can you figure out in what part of the process it is failing?
ie before the tool change? During the probe? etc
You could add some msg() commands to qt_auto_probe_tool.ngc to help in that regard.
  • SanzuiWorks
  • Senior Member
  • Senior Member
23 Jul 2024 08:04 #305900 by SanzuiWorks
Thanks for the reply!I tried the installation again.I got to the point where the machine was working, but REMAP didn't work.I want to get back to that point soon.MDI↓T1 M6↓Move to [CHANGE_POSITION]↓Nothing happens. No dialog box appears.I don't know why, but I'm sure I'm missing something.No matter how many times I try to configure it, I can't keep up with it.
23 Jul 2024 14:38 - 23 Jul 2024 14:39 #305920 by COFHAL
I notice this error after having changed a tool with M6 Tx. I attach my INI file and that of qtdragon_hd.pref. The entire change process makes it correct. The problem is that once it has measured the new height of the tool, the Z axis goes up and stops with that error.
File Name: YYS6040_QD.ini
File Size:7 KB
File Name: qtdragon_hd.pref.txt
File Size:4 KB
Last edit: 23 Jul 2024 14:39 by COFHAL.
  • SanzuiWorks
  • Senior Member
  • Senior Member
23 Jul 2024 23:05 - 23 Jul 2024 23:06 #305942 by SanzuiWorks
The error occurs after a tool change.
Cycle Start
Move to [Tool_change_position]
Replacement instructions
Go to [VERSA_TOOLSETTER] and measure the tool
Go to WORK
Z limit error
Linear move on line 17 would exceed joint 2's negative limit
Cannot switch pages while in AUTO mode
It looks like the z-axis is now jumping out of the machine area.
Last edit: 23 Jul 2024 23:06 by SanzuiWorks.
  • SanzuiWorks
  • Senior Member
  • Senior Member
25 Jul 2024 05:50 - 25 Jul 2024 06:53 #306003 by SanzuiWorks
I still don't know the cause, but I think I'm getting a little closer to the answer.
What value does <zworkoffset> represent?
#<zworkoffset> = [#[5203 + #5220 * 20] + #5213 * #5210]
When calculating using <touch_result>, the results will be more accurate if you omit <zworkoffset>.
#<touch_result> = [#5063 + #<zworkoffset>]
In other words, when G92/G52 = 0 and G54, the value of <zworkoffset> is "0", right?
<zeorkoffset> value is around "110", so I think that's the cause.
I don't know if the "ini" settings are wrong or what the cause is. Do you know anything?
Last edit: 25 Jul 2024 06:53 by SanzuiWorks.
25 Jul 2024 06:14 #306005 by Aciera
That is correct.
The value is around "110", so I think that's the cause.
this would indicate that #5063 (which should hold the Z coordinate value at the time the probe tripped) has the value 'around 110'.
Typing this command in MDI should show the current value of parameter 5063:
(DEBUG, value = #5063)
linuxcnc.org/docs/html/gcode/overview.ht...:numbered-parameters
  • SanzuiWorks
  • Senior Member
  • Senior Member
25 Jul 2024 06:34 - 25 Jul 2024 06:45 #306008 by SanzuiWorks
I wrote it poorly.
The value of “110” is indicated by <zworkoffset>.
This value is -120.
#<touch_result> = #5063
When I changed it to this it worked fine.
I don't know what the results would be if there was an offset.
Last edit: 25 Jul 2024 06:45 by SanzuiWorks.
  • SanzuiWorks
  • Senior Member
  • Senior Member
25 Jul 2024 08:19 - 25 Jul 2024 08:22 #306012 by SanzuiWorks
Resets the Z value of the active coordinate system.
Before getting #<zworkoffset>, you must reset the Z value of the active coordinate system.
;Resets the Z value of the active coordinate system
G10 L2 P#5220 Z0
Last edit: 25 Jul 2024 08:22 by SanzuiWorks.
