[qtragon]When should you use "Pause for jogging"?
  • SanzuiWorks
  • SanzuiWorks's Avatar Topic Author
  • Senior Member
  • Senior Member
25 Jul 2024 14:37 - 29 Jul 2024 07:07 #306017 by SanzuiWorks
In what situations would you use "Pause For Jogging" in the manual tool change message dialog?
Select this to rotate the spindle.
I'm not familiar with CNC operations, so I had some doubts.
(When using qtdragon for manual tool change.)
Last edit: 29 Jul 2024 07:07 by SanzuiWorks.
28 Jul 2024 09:26 #306222 by andypugh
Replied by andypugh on topic When should you use "Pause for jogging"?
I think that this is probably a feature of the UI that you are using, rathe than a base LinuxCNC feature.
One use would be to move the spindle to a more convenient place to perform the manual toolchange.
  • SanzuiWorks
  • Senior Member
  • Senior Member
29 Jul 2024 07:05 #306309 by SanzuiWorks
Replied by SanzuiWorks on topic When should you use "Pause for jogging"?
You're right. The question is about the qtdragon GUI.
That's true!
If you change the AUTO mode from , you can move the spindle position.
I haven't found a useful way to use it yet, but it's good to know that it's possible.
This GUI not only allows you to escape the Z axis when pausing without stopping the program, but also allows you to optionally move and rotate the spindle when manually changing tools.
Time to create page: 0.354 seconds
