[QtDragon] Beginner Questions
  • anfänger
  • anfänger's Avatar Topic Author
  • Platinum Member
  • Platinum Member
12 Aug 2024 11:00 - 12 Aug 2024 13:23 #307536 by anfänger
[QtDragon] Beginner Questions was created by anfänger
I am considering changing from ProbeBasic to QtDragon.
While setting up my newest machine I started with ProbeBasic but I needed to update vom LinuxCNC 2.8 to 2.9 t get some new features.
I usually modify modify my VCP quite a bit to fit my machines. But with ProbeBasic I always ran into trouble to bring this changes to a newer version.
So here are my questions:
I can develop my one tab in QT Designer in embed it into QT Dragon without touching the main ui file, so when there is an update I don't lose my work?
Are the Hal Widgets includes in QT Designer?
And not for my current machine, but maybe I swap my lathe later. Are the lathe Macros already implemented somehow? or easy to integrate?
Are there some best practices?
I Usually use the custom parts for monitoring the machines additional functions, like lube, spindle gears, hydraulic chuks, Column control and status IO's
Thanks Patrick
Last edit: 12 Aug 2024 13:23 by anfänger.
12 Aug 2024 13:54 #307545 by cmorley
Replied by cmorley on topic [QtDragon] Beginner Questions
Yes qtdragon can embed panels in specific positons without modifying the main screen.
I would recommend building the panels in Qtvcp though.
Some of the qtdragon Sims have embedded panels as demonstration.. usually vismach graphics.
